'94 Ram 4x4 front coil spring brackets #1698897
11/14/14 12:33 PM
11/14/14 12:33 PM
Pittsburgh,PA
RTSrunner Offline OP
Pittsburgh,PA
I have a friend working on a 1994 Ram 2500 4x4.The front coil spring brackets are rusted on the front axle,a Dana 60. Are there any known aftermarket repair mounts available to fix this issue? I told him to check with Mopar first,but my guess is they'll need to be fabricated or replace the axle assembly.
Thanks,RT
Re: '94 Ram 4x4 front coil spring brackets [Re: RTSrunner] #1698898
11/14/14 11:51 PM
11/14/14 11:51 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Check recall 835... applies to V-10 and CTD trucks.
Re: '94 Ram 4x4 front coil spring brackets [Re: J_BODY] #1698899
11/14/14 11:58 PM
11/14/14 11:58 PM
New Brunswick, Canada
TrxR Offline
TrxR  Offline
I had the same problem with a 96 1500 and had a new one fabricated as they are not available separate, you have to buy the whole housing.
Re: '94 Ram 4x4 front coil spring brackets [Re: J_BODY] #1698900
11/15/14 12:09 AM
11/15/14 12:09 AM
Pittsburgh,PA
Pittsburgh,PA
Thanks,I'll check the recall for info. RT
