light weight disc brakes #1698674
11/13/14 04:38 PM
11/13/14 04:38 PM
,Pa.
68dodge Offline OP
68dodge  Offline OP
,Pa.
does anyone make a light weight disc brakes for the 72-79 Dodge D-100 trucks? Trying to lighted the truck for racing.
Re: light weight disc brakes [Re: 68dodge] #1698675
11/13/14 06:27 PM
11/13/14 06:27 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
i think you are stuck with the hub that fits the spindle and those are the big clunky stock rotors---now it you had a drum brake setup you could knock the drum off and use the relatively light hubs and some racing rotors from speedway and make your own brackets for a gm metric caliper....
