Who wants to buy a mopar a turbo kit?
#1698297
11/13/14 12:38 PM
11/13/14 12:38 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
With all of the buzz about turbo’s right now, I am at a point where I’m seriously looking at producing turbo “kits” for mopars. The idea is that these will be SIMPLE blow through carb bolt on kits with everything you need from cylinder head to carb hat.
The idea will mainly be focused on the 500~700hp small block crowd, as the motors and cars plentiful, small turbos are lower cost to feed smaller motors, and many production manifolds are easy to come by. I believe I have a plan to eliminate any need for cutting/welding, and bolt right up. Kits would be for A, B, and E bodies, and AT LEAST priced competitively with equivalent HP centrifugal supercharger kits (if not better).
What do you guys think? Any interest?
Re: Who wants to buy a mopar a turbo kit?
[Re: dizuster]
#1698300
11/13/14 01:23 PM
11/13/14 01:23 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
No big blocks... (at least to start with).
-No manifolds (which would require custom headers) -Expensive (big) turbo's required to feed them -There are a lot more people looking for 500~700hp then 700~1000hp
Kits would be double what I can build a small block one for... so I'm guessing the market isn't there for that.
I guess I'll have to fab up my own then...
[Re: dizuster]
#1698303
11/13/14 01:50 PM
11/13/14 01:50 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
I think it is a great idea, and will fill a void for sure. Unfortunately my LA/A-body project got put on the back burner after I picked up my Belvedere, and I have the means to set up one myself (just not the time) A couple concerns I might have - mopar guys are cheap - small market (how many guys are buying centrifugal blower kits?) - everyone will want something different (air/air, air/water, Meth), and people are difficult to please - must use purple cam Good luck with it!
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: dizuster]
#1698305
11/13/14 02:51 PM
11/13/14 02:51 PM
imho, The most valuable thing you have to offer is your knowledge you have gained from actually having done this....
From what I have read, I am assuming you would procure the turbo, blow-off valve, wastegate, carb, used manifolds, oil lines, etc., then manufacture the turbo mounting bracket, piping from the exhaust manifolds to the turbo, the piping from the turbo to the carb, and possibly exhaust piping off the turbo.....and package it together with instructions....
The marketing drawback I see is maybe the guys doing low-buck, low hp small block turbo's.....might be low-buck.....and not be able to spend thousands at a time....so just offering the parts you make, and letting them know where/what else to buy later might be better.
It seems like it would be very low risk to just make a few copies of exactly what you have now, and see what the market thinks.
[Re: dizuster]
#1698308
11/13/14 03:41 PM
11/13/14 03:41 PM
Posts: 22,695 Bitopia
jcc
Bitopia
Good idea, I'm interested. Just remember, it seldom is as easy as it first seems, this is a very tough crowd to please, and if it was easy, others will soon copy what you have done, cheaper.
[Re: dizuster]
#1698310
11/13/14 05:02 PM
11/13/14 05:02 PM
Posts: 20,626 in a cattle trailer down by th...
Guitar Jones
I'm interested too. I've been toying with the idea of building a turbo car for the street. I still want to do a diesel though but there isn't a lot to choose from and the Cummins is just too heavy.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: BPE]
#1698311
11/13/14 05:17 PM
11/13/14 05:17 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Rod are you able to keep any 360 4.25 crank around? I want to sell all my 4 inch stuff and go 4.25 but I don't want to do it if I can't get one when my stuff sells, 4.125 is not worth the effort unless I was starting from scratch.
