Page 6 of 10 1 2 4 5 6 7 8 9 10
Re: Who wants to buy a mopar a turbo kit? [Re: dizuster] #1698397
12/27/14 12:38 PM
12/27/14 12:38 PM
Dayton, OH
1980volare Offline
My man card has just been revoked.
1980volare  Offline
Dayton, OH
Flipped truck manifolds will fit on an fbody with manual steering. If it's got PS I don't see it fitting at all. Some minor clearance on the passenger side is needed. Nothing a BFH won't handle.
Re: Who wants to buy a mopar a turbo kit? [Re: dizuster] #1698398
12/27/14 02:52 PM
12/27/14 02:52 PM
Dayton, OH
1980volare Offline
1980volare  Offline
Dayton, OH
Let me try some pics
Re: Who wants to buy a mopar a turbo kit? [Re: 1980volare] #1698399
12/27/14 02:55 PM
12/27/14 02:55 PM
Dayton, OH
1980volare Offline
1980volare  Offline
Dayton, OH
Another
Re: Who wants to buy a mopar a turbo kit? [Re: 1980volare] #1698400
12/27/14 02:58 PM
12/27/14 02:58 PM
Dayton, OH
1980volare Offline
1980volare  Offline
Dayton, OH
Last one
Re: Who wants to buy a mopar a turbo kit? [Re: 1980volare] #1698401
12/27/14 02:59 PM
12/27/14 02:59 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Could you post a pic of the relation ship of the torsion bars/sway bar in relation to the fan and shroud? A-Body prototype is being built right now.
Doug
Re: Who wants to buy a mopar a turbo kit? [Re: dvw] #1698402
12/27/14 03:20 PM
12/27/14 03:20 PM
Dayton, OH
1980volare Offline
1980volare  Offline
Dayton, OH
It's not a factory fan or radiator.
Re: Who wants to buy a mopar a turbo kit? [Re: 1980volare] #1698403
12/28/14 12:06 PM
12/28/14 12:06 PM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
Looking for fbody pics specifically in the k frame area under/in front of the crank pulley.
Need to make sure the crossover will clear.
By the way guys, looks like I have overcome the power steering issue. I will be able to offer it to work with it without any huge tearups!
Couple of spy photos showing the area I need the f body pics.
Re: Who wants to buy a mopar a turbo kit? [Re: dizuster] #1698404
12/28/14 12:07 PM
12/28/14 12:07 PM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
2
Re: Who wants to buy a mopar a turbo kit? [Re: dizuster] #1698405
12/28/14 02:21 PM
12/28/14 02:21 PM
Dayton, OH
1980volare Offline
1980volare  Offline
Dayton, OH
Just went a took some for you. Don't mind my mess Lol
Can't really get the same view of the underside, but from your pics I can tell you that crossover will hit the torsion bars. What size is that crossover, it looks big to me but could just be the pictures. I'm going 2.25, mine is going to end up very similar to yours but with the turbo slightly more towards the passenger side I believe, so I can retain my current radiator and fan setup. These s475s are pretty big and heavy lol
Re: Who wants to buy a mopar a turbo kit? [Re: 1980volare] #1698406
12/28/14 02:22 PM
12/28/14 02:22 PM
Dayton, OH
1980volare Offline
1980volare  Offline
Dayton, OH
2
Re: Who wants to buy a mopar a turbo kit? [Re: 1980volare] #1698407
12/28/14 02:24 PM
12/28/14 02:24 PM
Dayton, OH
1980volare Offline
1980volare  Offline
Dayton, OH
3
Re: Who wants to buy a mopar a turbo kit? [Re: 1980volare] #1698408
12/28/14 05:04 PM
12/28/14 05:04 PM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
Thanks a lot. Could you measure the edge of the lower pulley to the top of the torsion bar for me?
Re: Who wants to buy a mopar a turbo kit? [Re: dizuster] #1698409
12/28/14 05:32 PM
12/28/14 05:32 PM
Antioch, CA
lucky13 Offline
lucky13  Offline
Antioch, CA
Mind if I ask what turbo you're gonna be including with your kits?
www.racemagnum.com
1954 Plymouth Savoy 2 door
Re: Who wants to buy a mopar a turbo kit? [Re: lucky13] #1698410
12/28/14 05:42 PM
12/28/14 05:42 PM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
My kits will include anything from 69mm to 88mm depending on what the user is looking to do. 400hp and 900hp crowds will both have my support.
Re: Who wants to buy a mopar a turbo kit? [Re: dizuster] #1698411
12/28/14 06:18 PM
12/28/14 06:18 PM
Dayton, OH
1980volare Offline
1980volare  Offline
Dayton, OH
Just a tad under 3" but that's with a under drive crank pulley.
Re: Who wants to buy a mopar a turbo kit? [Re: 1980volare] #1698412
01/17/15 12:15 PM
01/17/15 12:15 PM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
Just wanted to provide an update to this for those following along...
I'm most definitely still moving forward on this. I'm hoping to finish up the turbo locating/mounting bracket tomorrow. Everything is really coming together nicely with these.
Couple of updates for you guys... I can confirm that:
-There WILL be power steering and non-power steering kits available
-The ONLY cutting to the car body anyone will have to do is a small 1/4" grind on the inner frame rail lip on and A-body to clear the stock magnum manifolds. Other then that, no other inner fender, firewall, core support, etc... cutting is required.
-You will be able to put this kit on with hand tools. No welding, machining, cutting, etc... required.
-You will not have to relocate your battery.
-You will be able to re-use your stock alternator.
-The kits will fit A,B, and E bodies. F/M are still up in the air because of the transverse torsion bars.
-I will be proving out the basic kit on a dead stock 5.2L magnum motor to show you guys what it will do on a budget.
-I will prove out the higher HP kit on my built 360 to show what you can do with a decent build.
No pics yet because the turbo is still moving around slightly, so I'd like to wait until I get the final location/layout completed before sharing... but stay tuned... they will be coming!!!
Re: Who wants to buy a mopar a turbo kit? [Re: dizuster] #1698413
01/17/15 03:40 PM
01/17/15 03:40 PM
Creston, Iowa
3
340man4ever Offline
340man4ever  Offline
Creston, Iowa
Thank you for the update.....much appreciated
Curator at Adams County Speed Shop
Re: Who wants to buy a mopar a turbo kit? [Re: 340man4ever] #1698414
01/17/15 08:07 PM
01/17/15 08:07 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Re: Who wants to buy a mopar a turbo kit? [Re: cudadoug] #1698415
01/19/15 01:37 AM
01/19/15 01:37 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
I'll be following this.....
I have planned on boosting a BB as BBs are all I have on hand...but this has my attention!
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Who wants to buy a mopar a turbo kit? [Re: Von] #1698416
01/19/15 02:41 AM
01/19/15 02:41 AM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
I found the intake for my twin setup.
