blue streak caps help #1698158
11/12/14 11:20 PM
11/12/14 11:20 PM
Jacksonville , Fl
V
Volare4life Offline OP
V
Jacksonville , Fl
So I have searched and searched, and I am trying to find info on big block electronic ignition dizzy caps from blue streak and could only find info on the blue streak CH-409X cap, but not info on the CH-400, visually it appears the ch-409X just got the emission nipple vent thing on top, and the CH-400 didn't, can anyone tell me if that is the only difference between the caps, Also this might sound dumb but can you swap normal electronic ignition SB( pre magnum) and BB caps ?
Thanks,
-Mike
The answers are out there you just got to look hard enough
Re: blue streak caps help [Re: Volare4life] #1698159
11/12/14 11:27 PM
11/12/14 11:27 PM
(1) I do not know (2) there are no dumb Q's/yes they are the same
Re: blue streak caps help [Re: RapidRobert] #1698160
11/16/14 08:49 PM
11/16/14 08:49 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
electronic ignition v8 caps are same as single point v8 caps...
