Open or Closed Chamber Cylinder Heads?
#1697587
11/11/14 07:27 PM
11/11/14 07:27 PM
Posts: 1,562 Macomb, MI
vinnyd76
Macomb, MI
I have a bare 440 HP engine block that will be bored .020 or .030 over (magnaflux process already complete - block currently standard bore). No components have been purchased thus far. I'm considering forged pistons and 906 heads. The vehicle that this will be installed in is TBD at this point. However, 60% of time the vehicle will be driven to around town to car shows, cruising, etc...
I was told that I should change the main cap bolts to studs (better clamp load, long term durability over original bolts). Thoughts?
I welcome your thoughts on components, compression ratio, etc...
Re: Open or Closed Chamber Cylinder Heads?
[Re: vinnyd76]
#1697589
11/11/14 07:57 PM
11/11/14 07:57 PM
RapidRobert
main bolts/hyper pistons. Quench is better but are you considering 67 915 heads or source ($$$) or eddy ($$$) closed chamber heads to get it.
[Re: DaytonaTurbo]
#1697594
11/13/14 02:39 AM
11/13/14 02:39 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
If you do a set of aluminum closed chambered heads with a piston that sits flush with the deck, you can use a standard .040 compressed thickness head gasket. This combination will get you a quench build which will allow you to run a little more compression on pump gas and make a little bit better power. An aluminum headed quench built 440 with a mild cam can do 10.5 compression on pump gas where an open chambered 906 iron headed 440 would top out in the low 9's compression range.
This is the preferred way to setup your engine these days, but by no means the only way. Another consideration is cylinder heads. If you have a junker set of 906's that need to be rebuilt, then buying a set of aluminum aftermarket heads like the edelbrocks or 440source's starts to look really attractive because the price to rebuild a set of stockers is not cheap, not to mention the benefits of the extra flow and improved cylinder head design and materials of the aluminum heads. If you have a good set of iron heads already done up, then you can look at a set of dome pistons you can grind for quench.
This is good advise I completely agree with. I ran 906 heads back on my old 440 but I do my own head work (or did until my back went out) and I could rebuild my iron heads myself and save a ton of money but unless you do your own head work its not much if any more to just go with aluminum heads like the Stealth or Eddy's and if you want to go faster and spend more you can go to Indy or Victors or any of a few brands out there. But in todays market its hard to beat the aluminum heads with closed chambers to build a nice quench eng. Ron
