2001 ram not shifting #1696893
11/10/14 09:38 AM
11/10/14 09:38 AM
n.e. pa.
65rbdodge Offline OP
n.e. pa.
this is one of the trucks i drive at work- its a 2001 ram 4x4 360 auto. I`ve been told its the 3 trans its had in it. it shifts fine when its cold but after 5 minutes of driving it does not want to shift. if I shift it into neutral and then back to drive it will shift into the next gear. there does not seem to be any slipping at all in any gear. any ideas?
Re: 2001 ram not shifting [Re: 65rbdodge] #1696894
11/10/14 02:24 PM
11/10/14 02:24 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Isn't there a valve in the cooler line that has been known to go bad and stop fluid flow?
Re: 2001 ram not shifting [Re: stumpy] #1696895
11/13/14 03:14 AM
11/13/14 03:14 AM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Possibly governor pressure sensor in the valvebody.Also check for a binding throttle cable on the t-body and the other end down by the trans.
Re: 2001 ram not shifting [Re: SALEM1912] #1696896
11/13/14 03:58 AM
11/13/14 03:58 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
a bad antilock sensor in the rearend can also affect shifting....
