How strong are the stock 440 cast cranks???? #169558
12/17/08 09:30 PM
12/17/08 09:30 PM
The Grand State of Confusion-O...
SKR8PN Offline OP
SKR8PN  Offline OP
Good enough for a 4000lb B-body w/automatic street car?
This is for a customer, and will never see the track. He just wants something that sounds good, that he can beat on every once in awhile, but he also only wants to build this engine one time.
The core engine is a low mileage unit out of a motorhome.
Use the crank or toss it?
Karma has no menu. You get served what you deserve.
Re: How strong are the stock 440 cast cranks???? [Re: SKR8PN] #169559
12/17/08 09:34 PM
12/17/08 09:34 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Don`t see why not..........I know someone running deep 9`s w/a cast small block crank and he spins it up pretty good.
Re: How strong are the stock 440 cast cranks???? [Re: Thumperdart] #169560
12/17/08 10:02 PM
12/17/08 10:02 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
My motor started out in a full size B 100 short wheel base van. Untouched iron heads and next to no cam yet still went 14.20's. Still have the same rotating assy (cast crank, 6pk rods) since 2000.
I say use it
Re: How strong are the stock 440 cast cranks???? [Re: SKR8PN] #169561
12/17/08 10:03 PM
12/17/08 10:03 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
No problem. Use it.Mopar cranks are not prone to breaking.
Re: How strong are the stock 440 cast cranks???? [Re: MoparforLife] #169562
12/17/08 10:20 PM
12/17/08 10:20 PM
Petersburg, Va
Darrell Offline
Darrell  Offline
Petersburg, Va
When I saw this thread, the first thing that came to me was about 18 to 20 years ago Herb McCandless was selling new Mopar 440 cast cranks for $50! At the time everybody wanted a steel crank but I wish I would have bought a few!
Re: How strong are the stock 440 cast cranks???? [Re: SKR8PN] #169563
12/17/08 10:50 PM
12/17/08 10:50 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
The cast crank in my 73 440 has seen a bunch of 11.70 passes in a 3500 pound 65 Plymouth turning 6500 rpm and lots of street miles I just put this same engine in my 73 dart so it is going to see lots more.This engine has not been apart in over 5 years now. so i say it should be fine with what you are going to do with it.Mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: How strong are the stock 440 cast cranks???? [Re: SKR8PN] #169564
12/17/08 10:53 PM
12/17/08 10:53 PM
north west, IN
larry890 Offline
larry890  Offline
north west, IN
where is qwk_enuf_511 hes been waiting for this question to come up.
Re: How strong are the stock 440 cast cranks???? [Re: larry890] #169565
12/18/08 12:23 AM
12/18/08 12:23 AM
Ohio
jdfpam Offline
jdfpam  Offline
Ohio
Can hold up to at least 560 HP and 7,400 RPM if properly tricked out.
Jeff Day
Precision Automotive Machine, INC
Canton, Ohio
(330)456-3045
Re: How strong are the stock 440 cast cranks???? [Re: larry890] #169566
12/18/08 08:39 AM
12/18/08 08:39 AM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
10.0's at 134 on spray.6 years and still like new.
WAXER
Re: How strong are the stock 440 cast cranks???? [Re: QWK_ENUF] #169567
12/18/08 09:35 AM
12/18/08 09:35 AM
SE Nunya
Bubba Offline
Bubba  Offline
SE Nunya
Re: How strong are the stock 440 cast cranks???? [Re: SKR8PN] #169568
12/18/08 09:56 AM
12/18/08 09:56 AM
i rebuilt a 440 with the stock cast crank and verything else stock in it except the cam. i used it in my 66 dodge tow car with the old 60's long rams on it for years. then removed it and install in the 66 baracuda bracket hotrod and went 12.20's for a few years. after that it came out and went into my 66 satelite for a few more years to test plate nitrous systems i was building. it would run low 11/s on 3 stages but finally broke the tin valley pan and sucked the heat insulator into the motor and spun all the bearings. so in retrospec they are ok to use for what he wants to do with his motor.
Re: How strong are the stock 440 cast cranks???? [Re: SKR8PN] #169569
12/18/08 09:58 AM
12/18/08 09:58 AM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Supposedly the NHRA stocker guys like 'em cause they weight about 5 pounds less, which is less spinning weight downstairs..
Re: How strong are the stock 440 cast cranks???? [Re: Bubba] #169570
12/18/08 10:15 AM
12/18/08 10:15 AM
SKR8PN Offline OP
SKR8PN  Offline OP
Looks like this crank is going back in service!!
Re: How strong are the stock 440 cast cranks???? [Re: SKR8PN] #169571
12/18/08 11:04 AM
12/18/08 11:04 AM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
this is the crank i ran in the first 10.0 race at norwalk.i also street drove big time with this crank.it is still std/std and i went a best of 10.05@134
click on my link in my sig and see the crank in action
believe it or not
WAXER
Re: How strong are the stock 440 cast cranks???? [Re: QWK_ENUF] #169572
12/18/08 11:46 AM
12/18/08 11:46 AM
SE Nunya
Bubba Offline
Bubba  Offline
SE Nunya
How about listing some combos please?
May next engine after the one I'm doing now will be all natrual... nothing exotic.. If it runs 10's , 11's or 12's I'l be happy..
440, 906 heads, small roller cam. set the lash once ayear. pump gas, I should be doing it now..
Re: How strong are the stock 440 cast cranks???? [Re: Bubba] #169573
12/18/08 12:31 PM
12/18/08 12:31 PM
Queens, New York
Harley Offline
Harley  Offline
Queens, New York
My first 440 was a cast crank motor that made about 525 hp at the crank. I ended up hurting the motor and had the rod journals cut .030 and put it back together. I ran that short block on the street for a couple of years before I retired it. It was sitting in my garage for a couple of years and then I sold it. I later found out that the same short block went into a car that was being sprayed with a 200 shot. I was shocked that it lived for a long time before it broke. So I would say yes to a cast crank in a street car.
Re: How strong are the stock 440 cast cranks???? [Re: Harley] #169574
12/18/08 05:20 PM
12/18/08 05:20 PM
the netherlands
3
383duster Offline
super street
383duster  Offline
super street
3
the netherlands
this roadrunner in the netherlands runs in de 10's for years and runs a 440 with cast crank, stock rods, light keith black pistons and a 4-speed and he is spinning it to about 7000 rpm, can't believe it stay's together!
http://www.youtube.com/watch?v=gGdjznzwZi4
Re: How strong are the stock 440 cast cranks???? [Re: Bubba] #169575
12/18/08 05:41 PM
12/18/08 05:41 PM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
1976 block and cast crank
eagle h beam rods
wiseco pro-true piston/ring kit
herbert D6H roller
weiand tunnel ram / 600 VC holleys
B1Bs heads
big shot kit
10.05 @ 134 spraying 200 hp
3235 lbs a body
WAXER
Re: How strong are the stock 440 cast cranks???? [Re: Sixpak] #169576
12/18/08 06:06 PM
12/18/08 06:06 PM
AndyF Offline
AndyF  Offline
Yep, I've talked to some NHRA stock guys who run cast cranks just to save a few lbs. They spin those motors hard too. I'd never use a cast crank myself but if someone wanted to go that way I'd never tell them that it wouldn't work. They do have a power limit but I'm not sure what it is.
Re: How strong are the stock 440 cast cranks???? [Re: Darrell] #169577
12/18/08 06:08 PM
12/18/08 06:08 PM
AndyF Offline
AndyF  Offline
I bought a few of those new cast 440 cranks. Still have them after all of these years! I'll probably never use them, they just sit on the shelf.
