Re: Trick Flow introduces BBM heads
[Re: DoubleD]
#1694245
11/13/14 03:14 PM
11/13/14 03:14 PM
Posts: 7,131 Amarillo, Texas
BBR
Amarillo, Texas
Since 2007 I have owned 2 sets of Trick Flow Powerport 290 heads for big Fords and their casting and machine work quality is fantastic. I never once had an issue with either set.
I am excited they are using their resources to expand their product line to any Mopar instead of using those resources to develop yet another SBC or SBF head.
Drag Week 2011 - 77th place - DD Drag Week 2012 - 2nd place SRBB N/A Drag Week 2014 - Kapooya RMRW 2018 RMRW 2020
[Re: Fury Fan]
#1694246
11/14/14 03:05 AM
11/14/14 03:05 AM
Posts: 2,026 Trumbull,CT.
jim sciortino
Trumbull,CT.
Great......
Another head that drops right in the middle of a sea of mundane offerings to power a BBM down Main St.. What's that, about a dozen or more BBM heads that can't outflow a decent SBC piece, but still have the ability to bust a piece of junk 45 year old block???
No good iron, or CG blocks and not a single head casting that can top the ancient PSO.
I NEVER thought I'd see a day when it was better to be a Pontiac guy, as far as the performance aftermarket and R & D worlds are concerned. What's next.....another stock style HEMI head???
What an absolute farce the MOPAR aftermarket is......
Trick Flow doesn't make blocks...perhaps you should whine to Block companies about the lack of BB mopar blocks...and not whine about getting a better quality of cylinder head than most of the current offerings.
Reading comprehension issue???
Did I SAY they make blocks???
I guess all these low power engines need a "better quality" cylinder head because the Ebrock, Indy, B1 and whatever other heads are out there in this category of cylinder head are just coming apart at the seems.
OU812 doesn't have a reading comprehension issue.
Trick Flow doesn't make *any* products of the type you want, and you're upset because they're releasing something new of what they *do* make. If we follow your logic there should be no new products permitted by anyone unless they release a cylinder block first. Are you upset at all the different intake manifolds out there too???
So go get a home equity loan, find a pattern shop and casting house, and start working on it yourself. You'll find out quick why companies aren't flocking to do blocks.
Obviously you have the same reading comprehension issue.
Since my keyboard doesn't type in crayon, perhaps you should go back and re-read (SLOWLY) my original post.
Point out where I bemoaned Trick Flow not making blocks, as OU812 alluded to, or where I stated it should be Trick Flow that produces an upgrade to the ancient PSO, or Millennium HEMI.
If you, or anyone else cannot understand what you are reading, why comment and prove to the world your lack of comprehension??? No self esteem, perhaps??? Ignorant, perhaps??? An OU812 butt-hurt cheerleader, perhaps???
[Re: jim sciortino]
#1694247
11/14/14 03:39 AM
11/14/14 03:39 AM
Posts: 5,484 SoCal
Brian Hafliger
SoCal
Great......
Ha ha ha....your reply seems to describe yourself more than anyone else could have!
Brian Hafliger
[Re: Brian Hafliger]
#1694248
11/14/14 06:08 AM
11/14/14 06:08 AM
jim sciortino
Trumbull,CT.
Great......
Certainly not you, or that other simpleton.....
What's the problem......upset that you can't deny a single point in my original post, so you took it completely out of context in your idiotic response, or are your feelings hurt because I didn't pen a glowing welcome to yet ANOTHER run-o-the-mill cylinder head for a BBM that couldn't sniff a decent SBC, or SBF offering???
[Re: 64Post]
#1694249
11/14/14 12:01 PM
11/14/14 12:01 PM
Posts: 13,182 aZLiViN
J_BODY
aZLiViN
Well, the more I hear about their quality, the more I'm interested. I'm tired of having an exhaust port on my MCH RPMs welded up to fix a water leak.
Well thank the god of your choice that the heads CAN be welded..... I personally know of a Mopar head that can't due to the crap they casted them of.
[Re: jim sciortino]
#1694250
11/14/14 02:42 PM
11/14/14 02:42 PM
Posts: 1,271 Vista, California
67Satty
Vista, California
Great......
Why can't you just be happy for us little peons with the street/strip cars in the 400-600 hp range??? If their claims are true and they really are ready to bolt on (I know that might be a big if), they've made a head that will outflow both the RPM and the standard-port Indy EZ and beat both in price when you factor in not having to take them into someone before you can even think about using them. And why shouldn't they start with the head that they would sell the most of as the first offering?
How many total racers are even out there running something that needs more than what these can do compared to how many of us are out there with street/strip cars having fun driving our cars everywhere and driving them to the track?
[Re: BBR]
#1694251
11/14/14 03:20 PM
11/14/14 03:20 PM
Posts: 19,304 Las Vegas
Al_Alguire
Las Vegas
From SEMA new products display
[Re: jim sciortino]
#1694252
11/14/14 03:29 PM
11/14/14 03:29 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
Dang, nice slide into childishness, dude. Did you accidentally put your maxipad on tape-side up or what???
I had someone explain it to me. And reeaal slow, ‘cuz I’m a simpleton.
They said there’s a new part out there, and even though 95% of us will embrace it, it’s not the type of part **you** want, and you’re grouchin’ about it -- even though it doesn’t affect you whatsoever and you had no skin in bringing it out.
They said it seems you’ve forgotten what it was like ~10 years ago when this affordable aftermarket stuff didn’t exist for us.
They also thought if somebody did release a block, it probably wouldn’t be configured exactly the way you want anyway and you’d grouch about that.
[Re: 67Satty]
#1694253
11/14/14 03:43 PM
11/14/14 03:43 PM
jim sciortino
Trumbull,CT.
Great......
The reason I'm not "happy" is because there are already multiple perfectly adequate choices for the "peons", as you call them, for street and bracket builds. Do you know how I know??? Because I had a regularly street driven low 9sec N/A BBM in the early 90s using the 1st Indy offerings. Since then, numerous other heads have been released that cover that performance level and most of them have been just fine.
I am the last person that needs to be lectured on the issues of the economics of MOPARLAND, or the inherent problem with the 40 we give up to the BBC in bore space and the 100 we give up to Ford, but I also know that other makes, including Pontiac are seriously handicapped when it comes to bore centers, yet the Pontiac aftermarket has made huge strides in high potential head and block castings........including from Edlebrock.
That MOPAR racers can't pick up the phone with credit card in hand and order even a single brand new, state-of-the-art iron, or CG engine block (big, or small) for a reasonable market driven price and have it in hand in a couple days, along with cylinder heads either finished, semi finished, or raw, that incorporate the advances that have been made since the PSO and Millennium were cooked up............is ludicrous.
It has nothing to do with not being "happy" for the "peons", as you call them, because not only have I spent WELL over 300k since 1976 when I began pouring money into this hobby..........I am also one of those "peons" you labeled.
What's really funny is......my friend and fellow "peon" recently scored a new set of W2s and is looking for a good guy to build him a street/strip 408 for his Dart. I recommended OU812.
[Re: 67Satty]
#1694254
11/14/14 03:45 PM
11/14/14 03:45 PM
Posts: 3,957 West Coast, CA
Troy
West Coast, CA
As soon as I saw this thread I new it was going to go down this road. Every time a new product comes out the arm chair quarter backs come out and think they could do a better job. If this new product does not work for you then move on.....no need to bash it!! Some of you people need to get out from behind the key board.....get in the real world and build something before you shoot off your mouth. ok, have a nice day.
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
[Re: jim sciortino]
#1694256
11/14/14 04:15 PM
11/14/14 04:15 PM
Fury Fan
Indiana
When you say 'really funny' in that context, what does that mean? I surely don't want my bad comprehension to garner more of your scorn. Can you no longer recommend him because you're in defend-my-sentences mode with him, or ???
[Re: jim sciortino]
#1694257
11/14/14 04:22 PM
11/14/14 04:22 PM
Posts: 3,391 Pa
Hot 340
Pa
This could be the best head in it's class for it's intended purpose.
Point out EXACTLY where I "bashed it", or learn how to read.
Since you have no trouble shooting your mouth off, anytime you want to step into the real world and try your luck with either of my "somethings"......feel free. I'm just a lowly street guy with a really good spot for you to come take my money.......in the real world.
Ya game???
Come on Jimmy, you aint got nothing fast.
[Re: Troy]
#1694259
11/14/14 04:43 PM
11/14/14 04:43 PM
jim sciortino
Trumbull,CT.
Ya game???
Next time, try to understand what you're commenting on BEFORE you comment.
