2013 DURANGO NO CRANK #1694109
11/04/14 02:53 AM
11/04/14 02:53 AM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
Just bought a 2013 hemi durango that was hit in left rear. I can not get it to crank go to acc to turn radio on. I have checked fuses and relays best I can. Am I gonna have to take it to Dodge dealer?
Re: 2013 DURANGO NO CRANK [Re: rickb67] #1694110
11/04/14 05:14 AM
11/04/14 05:14 AM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
what exactly are you saying here? it wont crank, wont go to acc, won't turn radio on?
Re: 2013 DURANGO NO CRANK [Re: rickb67] #1694111
11/04/14 05:22 AM
11/04/14 05:22 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Perhaps due to the wreck it was in, the ASD may have to be re-set: can be the case on the older models.
It's related to the shutting off the fuel pump in case of accident.
This new of vehicle (TIPM), it's probably a dealer only issue and you are at their mercy..........$120 an hour.
Mo' Farts
Moderated by "tbagger".
Re: 2013 DURANGO NO CRANK [Re: Golden-Arm] #1694112
11/05/14 12:55 AM
11/05/14 12:55 AM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
took it to dealer they popped out start button and stuck the square headed key in and it started.Dealer said someone probably found the start button in console and stuck it in. They have to be programmed to work.
