97 dakota fuel pressure regulator swap or bypass? #1694067
11/03/14 11:48 PM
11/03/14 11:48 PM
anacortes,wa
78asprin Offline OP
78asprin  Offline OP
anacortes,wa
Im doing a lsx swap in a buddy's 98 dakota. It needs 58 psi to ru the fuel injectors. I know the regulator is part of the fuel pump assembly but i was wondering if there is a way to bypass it or replace it with a higher psi regulator
Re: 97 dakota fuel pressure regulator swap or bypass? [Re: 78asprin] #1694068
11/04/14 05:12 AM
11/04/14 05:12 AM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
Later NGC Mopar pumps&regs are 60 psi,possibly you could modify one to work in the 98.1998 is JTEC system.50 psi.You could bypass it all if you wish also.
Leave the gun.......take the Cannoli's....Mike
