NV 3550 NOISE IN A 2001 TJ #1693323
11/01/14 07:49 PM
11/01/14 07:49 PM
Creedmoor, NC, USA
74Charger Offline OP
Creedmoor, NC, USA
MAKES DISTINCT GEAR NOISE IN 1ST THRU 3RD GEARS, BUT NONE IN 4TH & 5TH. ANYONE HAVE ANY IDEAS?
NO HISTORY ON THIS JEEP. LOOKING TO BUY, BUT CONCERNED.
Re: NV 3550 NOISE IN A 2001 TJ [Re: 74Charger] #1693324
11/01/14 09:57 PM
11/01/14 09:57 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Normally they make noise in neutral. I am unaware of any ordinary noises in gear though.
Re: NV 3550 NOISE IN A 2001 TJ [Re: Defbob] #1693325
11/02/14 12:39 AM
11/02/14 12:39 AM
Creedmoor, NC, USA
Creedmoor, NC, USA
This one sounds like it has no lube in it while in first thru third gears. Shift to 4 & 5, and you hear nothing.
Re: NV 3550 NOISE IN A 2001 TJ [Re: 74Charger] #1693326
11/02/14 12:45 AM
11/02/14 12:45 AM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
I would guess a bad input shaft bearing. Kinda odd yours is silent in 5th though. Usually a bad input bearing is silent in direct (4th) only since power is not directed through the countershaft.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: NV 3550 NOISE IN A 2001 TJ [Re: 71yelladustr] #1693327
11/02/14 12:57 AM
11/02/14 12:57 AM
Creedmoor, NC, USA
Creedmoor, NC, USA
Does entire transmission have to come apart to replace the bearing?
Re: NV 3550 NOISE IN A 2001 TJ [Re: 74Charger] #1693328
11/02/14 01:27 AM
11/02/14 01:27 AM
Missouri U.S.A.
Missouri U.S.A.
The FSM recommends splitting the trans case to replace the input bearing. Although, it can be replaced by just removing the front bearing retainer and snap ring. You just have to get creative to pull it out of the case.
10.02@134
Re: NV 3550 NOISE IN A 2001 TJ [Re: 71yelladustr] #1693329
11/02/14 03:24 AM
11/02/14 03:24 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
if you pull the tranny---- shop price should be below $700 if they put an entire kit in it---you might use it as a bargaining chip if you really like the unit.....
