'72 - '74 Dodge Truck Bumpers, Are Front and Rear Same? #1692712
10/31/14 04:44 AM
10/31/14 04:44 AM
Rancho Cucamonga, CA
D_C Offline OP
D_C  Offline OP
On '72 - '74 Dodge Truck Bumpers the Same, front and Rear (for the Flush Mounted not the step type rear bumpers that is)? In photos they appear pretty much the same. Just wondering. Thanks
Re: '72 - '74 Dodge Truck Bumpers, Are Front and Rear Same? [Re: D_C] #1692713
10/31/14 01:13 PM
10/31/14 01:13 PM
Orange Park FL.
LilRed7879 Offline
LilRed7879  Offline
Orange Park FL.
I believe they are not the same one the front is slightly curved and taller the rear is straight. Also the front mounts with 4 bolts the rear has 6.
David S.
Part Time Owner
Dodge Connection
www.dodgeconnection.com
904-209-9388
Re: '72 - '74 Dodge Truck Bumpers, Are Front and Rear Same? [Re: LilRed7879] #1692714
10/31/14 01:33 PM
10/31/14 01:33 PM
D_C Offline OP
D_C  Offline OP
Thanks for the reply/info. Just thought it might make my search easier. The rear bumper on the W200 pickup is a Step-Type and it's bent up / contorted. Figured I would replace with a flush type bumper.
Re: '72 - '74 Dodge Truck Bumpers, Are Front and Rear Same? [Re: D_C] #1692715
10/31/14 03:19 PM
10/31/14 03:19 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Fronts arent the same as the rear. Front is the same till 82 as well as the non step rear.
LMC sells Non step rears but you'll need to source the brackets
Re: '72 - '74 Dodge Truck Bumpers, Are Front and Rear Same? [Re: 76dodgeboy] #1692716
10/31/14 03:56 PM
10/31/14 03:56 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
If it helps, the later 80's bumpers are not identical to the earlier ones but they bolt up and look pretty good on the older trucks.
I have mechanical Aptitude.
I can screw up anything.
Re: '72 - '74 Dodge Truck Bumpers, Are Front and Rear Same? [Re: D_C] #1692717
11/01/14 08:10 AM
11/01/14 08:10 AM
Pyeongtaek, South Korea
69HemiGTX Offline
69HemiGTX  Offline
Here you go.
OIF V and OEF X veteran and proud of it!
