Re: Brake pedal question
[Re: stumpy]
#1691695
10/28/14 04:06 PM
10/28/14 04:06 PM
Posts: 25,618 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Even without the push rod retainer the brake light switch should limit the pedal's up travel.
[Re: John_Kunkel]
#1691696
10/28/14 04:34 PM
10/28/14 04:34 PM
Posts: 21,050 Niles , Ohio
therocks
Niles , Ohio
John you can still lift it high and bend the arm the switch is on.I know I did it on ny 65 once playing with the pedal.I had to bend the SL arm back down.Rocky
Chrysler Firepower
[Re: therocks]
#1691697
10/28/14 08:47 PM
10/28/14 08:47 PM
RapidRobert
1st order of business is to check if the MC rear piston tapered "thimble" recess has the recess halfway down for the neoprene retainer to lock into & that that piece is on the pushrod. If no recess then that is a PB MC. Eberg said if that is your situation then lock it (the pushrod) in with RTV which sounds scary at first blush but if Eberg is OK with it then it's good enough for me
[Re: west]
#1691699
10/28/14 09:18 PM
10/28/14 09:18 PM
RapidRobert
You about to get a rebuilt MC to get a tailor made one but have the counter guy at your parts house cut a snip of vac line the same length as the machined recess at the end of the pushrod. They are virtually identical & will safely function fine. I forget the dia but just give him the pushrod & have him go back & use the roll of line that is a tight fit on the round nub (you only need a fraction of an inch for length). Cut a slight groove in it lengthwise end to end on the outside for air to excape as it locks into the piston blind hole for a good secure fit
