Re: 63 D100 Big Block Bellhousing
[Re: 440newport]
#1691543
10/28/14 04:45 PM
10/28/14 04:45 PM
dogdays
The flywheel will work for balance and is drilled for either an 11" or 12" B&B or diaphragm pressure plate.
It's got a lot of teeth, cant remember how many but it's way more than 140.
I just had the engine out of my '64D100. I replaced the stock 11" original disk with an 11.5" Schiefer disk and 12" McLeod pressure plate that I got for next to nothing. It's something like a 2800 lb clutch and I have no problems with pedal effort, although it is noticeably harder than the original.
One other thing: When disassembling, remove the seat and the trans tunnel cover to get better access to everything. Pull the transmission first. Then, unbolt the four motor mounts and the engine and bellhousing come out together. The bellhousing weighs a ton and wraps around the flywheel, easier to take off when the engine is out. The transmission will not pull out, bolted to the engine. I found out the hard way.
R.
[Re: Rhinodart]
#1691545
10/29/14 01:41 PM
10/29/14 01:41 PM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
I may have the bell housing you need...if you are going to try and keep it looking stock.....I'll try and get a part number off of it....it might be for the extended crank too...not sure.
Moparlee
[Re: Robbins]
#1691547
10/29/14 11:16 PM
10/29/14 11:16 PM
Posts: 485 Central California
MoParFish
Central California
Would keep the 4 speed. Not sure of other options on later big block bellhousings but haven't done any heavy research yet either. Extended crank??
[Re: MoParFish]
#1691548
10/30/14 09:36 AM
10/30/14 09:36 AM
Posts: 2,682 Des Moines IA
Soopernaut
Des Moines IA
You are probably going to need the parts from a 67-68 383 truck. After that they went to a mechanical clutch. Some of the larger trucks may have used a hydraulic clutch later.
1970 Dodge d100/eventually going on a 77 D100 frame
[Re: moparmarks]
#1691553
10/30/14 03:58 PM
10/30/14 03:58 PM
MoParFish
Central California
Here is the 61-68 BB truck housing. This takes the 172T fly wheel
That's the one. Thanks for posting the pic as I haven't been able to put my eyes on one yet. Would I have the 172T flywheel now on the 318?? I beleive I have the NP420 transmission.
[Re: dogdays]
#1691557
11/06/14 04:23 PM
11/06/14 04:23 PM
MoParFish
Central California
OP, I have my '64 D100 318 4-speed truck apart right now if you want pictures. But you gotta respond fast, I'm supposed too be driving it this weekend!
R.
Pics would be great! I sent you a PM with my email or post pics here on forum whichever is easier for you. Thanks!! Mike
