Re: Bored with 660hp....
[Re: Roughbird72]
#1687864
10/19/14 06:31 PM
10/19/14 06:31 PM
Posts: 12,379 Taxes & Virus's R-US, NY
Dragula
Work with what you have. A fast car seldom gets like that in one season!
I know....I have had this combo for a while. It should run better than it does, its just seems like its stuck...
[Re: Dragula]
#1687865
10/19/14 06:51 PM
10/19/14 06:51 PM
Quicktree
[Re: WO23Coronet]
#1687869
10/19/14 07:35 PM
10/19/14 07:35 PM
Dragula
Is it carb or injected? What's the combo run down?
Its carburated currently. It was injected previously and I have the injection unit but sold the ecu....
So currently it is:
484 cubes with a 4.15 crank and 4.31 JE pistons 11.5:1 compression mild .600 lift mechanical chevy cam 426-1 Indy heads flowing 400cfm 1000cfm carb and port matched intake
Car is 4.10 gears 31" tires 4500 stall car weighs 3220lbs
I had 4.56's in it last year with a 5000 stall, but hated all the rpm on the street.
It went 10.84 last year with the 4.56s and only 10.93 this year so far. Car is super drivable, so I have that covered...
[Re: Dragula]
#1687870
10/19/14 07:40 PM
10/19/14 07:40 PM
Posts: 1,845 Tampa
DusterDave
Tampa
What ET were you hoping to hit with it? Do a compression check.
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: B3422W5]
#1687875
10/19/14 09:13 PM
10/19/14 09:13 PM
Posts: 3,210 robin hood country
deaks
robin hood country
Do you use an A/F gauge ? i found mine invaluable when tuning my car. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: Dragula]
#1687877
10/19/14 09:28 PM
10/19/14 09:28 PM
Posts: 11,701 Portage,michigan
B3422W5
Portage,michigan
It lays over on the top end after shifting to 3rd, and even sometimes at the top of 2nd....
So at a race weight of 3480lbs, and a best trap speed of 124mph, what do you guys calculate? 660hp seems pretty close to me.
I know last year when it ran 10.84 there was another .10 in it of I sealed the carb to the hood.
I keep wondering about the MSD box though....
525...... Maybe 550 horse. Before my w5 motor I had a 416 with flat tappet, mildly ported Eddie heads. Car weighed 3450 at that time as it still had the bench seat in it( and otherwise bone stock in and out 70 Duster) cage and my 300 pounds in it, and it ran 10.70's at right at 124 through the muffs. I figured it for close to 550, maybe a hair less. I had a 6al do exactly what you are dealing with( lay over top of second and third) that I chased half of a season few years back..... Knocked about 5 or 6 tenths out of the car. Swapped in a digital 6 at that time and never did it again
[Re: B3422W5]
#1687878
10/19/14 09:35 PM
10/19/14 09:35 PM
deaks
robin hood country
My car is a genuine 590-600 hp it's lighter than yours but you should be going at least very low 10's at least 128-9 Mick
[Re: B3422W5]
#1687879
10/19/14 09:39 PM
10/19/14 09:39 PM
Just had an MSD do the same thing Friday on the dyno--swapped out the distributor for fresh MSD unit and whamo! All good and pulled like it should-- It can be the module in the dist as well--you would never think it--I thought it should work or not work but found out different Engine would just layover above 5000--put exactly same curve we always use black stop and one light silver one blue spring--and she went to work and ran great--always...I mean always something. I bet that Hemi is running out of fuel--has an elbow or something in the system or just not getting full voltage to the fuel pump--we always see giant swimming pool filler pumps with NO relays etc check and they are just not getting voltage--not pumping "what the box says" A drag car can run good with no symptom other than slow and low MPH--get fuel straight and it can really make a big diff China regulators are trouble too--Best for the $$ is Aeromotive stuff--class act quality and good support--regulators are very nice units but remember are o ring fittings not pipe thread when planning your plumbing.
[Re: ]
#1687880
10/19/14 09:55 PM
10/19/14 09:55 PM
B3422W5
Portage,michigan
His issue doesn't seem Rpm related( neither was mine) I am sure he wrings it out in first gear before shifting to second, and he didn't have any issues in first at all, only appear in the top of second. I thought my identical problem was fuel related/ vapor lock, etc,etc. Mine would run 9.90's on a normal pass, then about every second or third pass, it would run 10.50's, laying over at the top of second and all of third. The problem finally went to every pass it doing that. Swapped out the MSD box and that cured the problem. Had zero to do with fuel at all. That was why it took me so long to find the problem, I could have swore it was fuel delivery related
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
