Re: Bored with 660hp....
[Re: Monte_Smith]
#1687921
10/22/14 07:52 PM
10/22/14 07:52 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Boogers and dogdays posts should be plenty to enlighten you. Im very familer with the term and its easy to understand. You can only do so much area under the curve with a certain lift, diameter will regulate that. It was well explained IMO So yes a Chevy type diameter LOBE design can be ground on a Chrysler LOBE. Its still a Chrysler cam, but its got a Chevy Lobe. hey, we all cant know everything EDIT, Also Im not Implying that Dragula has a Hemi cam with a chevy type Lobe design.
[Re: Sport440]
#1687923
10/22/14 10:23 PM
10/22/14 10:23 PM
Posts: 12,383 Taxes & Virus's R-US, NY
Dragula
Funny how this post got off track, but I will say I have had cams in this motor that utilized the ramp you can attain with the Mopar lifters, and the mid range was much better. I noticed it right away in this combo....No more letting the local place pick the cam....Bullet confirmed this when I got a quote for a new one.
-That will definitly change this winter along with the ignition box, and maybe the intake valve size and the convertor.
[Re: Sport440]
#1687924
10/23/14 12:41 AM
10/23/14 12:41 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Trust me, I don't need "enlightened" on cam design nor how they work. I have probably had about 50 custom ground this year to my specs for various motors. Call the lobe whatever you want. As long as it opens and closes where I want it is all that matters to me..............but I will bow out of this thread anyway. Guess this stuff is just too far over my head..............LOL!!!
Monte
[Re: Dragula]
#1687927
10/23/14 07:05 AM
10/23/14 07:05 AM
Posts: 6,389 nielsville, minn.
quickd100
nielsville, minn.
What do I pay to get an engine dyno'd?? ZIP, Nadda, nothing. Of course I could have built a 3000hp motor for what I've spent on my dyno setup. Hope you find the problem Randy .Dave
[Re: Dragula]
#1687930
10/25/14 01:55 PM
10/25/14 01:55 PM
Posts: 2,131 New Lenox IL
cudadon
New Lenox IL
Well, the engine got down to the shop...We discussed going to a 528 and a real cam somewhere in the .640 lift range. And maybe a real convertor...
Depends on what you are going to do with the car
An 8" vertor will definately make better ET. But you may not like it's street manners.
Do the test to see how long it takes to fill a gallon can using the lines from the regulator. Don
