A518/46re Seal Question. #1687769
10/19/14 01:59 PM
10/19/14 01:59 PM
Salem
Grizzly Offline OP
Moparts Proctologist
Grizzly  Offline OP
Salem
Trying to install this transmission and it's putting up a fight, plus I have no idea what I'm doing.
I'm going to drop it back down to start all over and have a pretty good idea that I damaged the input seal. Can I replace this seal from the outside like you normaly would, or do I have to take the pump housing apart?
Thanks.
Mo' Farts
Moderated by "tbagger".
Re: A518/46re Seal Question. [Re: Grizzly] #1687770
10/19/14 02:32 PM
10/19/14 02:32 PM
Lakewood, Colorado
herkamer Offline
herkamer  Offline
Lakewood, Colorado
Same as a 727. Seal puller should get it
Matt
69 Dart Swinger 340
83 W350, Megasquirted with 46RH
Old news: 72 Demon street/race mobile
Latest: 70 Duster backhalf car
and even more
Re: A518/46re Seal Question. [Re: herkamer] #1687771
10/19/14 02:37 PM
10/19/14 02:37 PM
Salem
Grizzly Offline OP
Grizzly  Offline OP
Salem
Thanks!
Mo' Farts
Re: A518/46re Seal Question. [Re: Grizzly] #1687772
10/19/14 03:12 PM
10/19/14 03:12 PM
CENTRAL MINN
1965_PLYMOUTH Offline
CENTRAL MINN
be sure you get the converter placed all the way into the pump before you lift the tranny in place. you shouldn't be able to get your fingers in between the converter and inner bell housing when it's all the way in. sometimes I've had to stand the transmission up on end to accomplish this.
Re: A518/46re Seal Question. [Re: 1965_PLYMOUTH] #1687773
10/19/14 03:18 PM
10/19/14 03:18 PM
Salem
Grizzly Offline OP
Grizzly  Offline OP
Salem
Yeah, that's what I did wrong, I should have asked you Guys first.
I went by the distance from ring gear to bellhousing face when I was taking the old one out. About 1/2 inch.
I had the TC seated gently on the new one but figured it was way too far in there and thought it was pushing on the seal. Also wasn't sure how to slide the converter up to the drive plate when everything would be in place..... So, I pulled it away to match the one that came out.
Mo' Farts
Re: A518/46re Seal Question. [Re: Grizzly] #1687774
10/19/14 05:36 PM
10/19/14 05:36 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
There should be at least 1/2" from the bellhousing face to the drive lugs to ensure proper pump engagement.
