1992 Dodge Dakota 4x4 wiring problem #1687170
10/18/14 02:27 AM
10/18/14 02:27 AM
Des Moines, Iowa, USA,
dspeck5969 Offline OP
I put a re-built tranny in my truck with the help of my brother and his son. Well, my nephew disappeared on us when it came time to install the tranny. Question is, where can I find a wiring diagram for all or the wires and plugs that go on the tranny and transfer case?
DSpeck
D Speck ph. 515-443-6929
Re: 1992 Dodge Dakota 4x4 wiring problem [Re: dspeck5969] #1687171
10/19/14 12:23 AM
10/19/14 12:23 AM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
You should only have 4 things to plug in on the trans and transfer case. The neutral safety switch and the trans lockup/OD connector on the trans. On the transfer case, either a vacuum connector or 2 wire switch connector for 4WD and a connector for the vehicle speed sensor. They will only plug in one way so it should be self explanatory.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
