Re: New product 383/400 forged piston.
[Re: blue_stocker]
#1686996
01/03/15 02:52 AM
01/03/15 02:52 AM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
Just a heads up. Bobweight for the first engine with these flat tops. 2335G. Stock rods and stock steel crank.
Leave the gun.......take the Cannoli's....Mike
[Re: HotRodDave]
#1686999
01/25/15 09:50 PM
01/25/15 09:50 PM
mike s
Mi,U.S.A.
Chris, what con rod are you using? I don't think your set up will be an issue.
Dave, I haven't heard much on the heavy piston due to vacations. Everyone should be back this week. I doubt I can add enough weight to make them sealed power/trw stock forged pistons. I know how customers are and you can't please everyone. These are intended to be an upgrade not a replacement. Likely the 400 piston would save enough weight that the engine could be internally balanced. That should be a big plus for a 400 stock stroke owner. Steel 383 crank is now an option too.
BTW Owner of the first set is very pleased with his engine.
[Re: mike s]
#1687000
01/26/15 11:08 PM
01/26/15 11:08 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Yeah I know it seems kind of odd asking for a heavier piston but seems the only reason guys will build a 383 or 400 is to save $$$.
I do have a few steel cranks sitting around I could throw one in his motor.
[Re: BradH]
#1687001
01/28/15 05:21 PM
01/28/15 05:21 PM
BradH
Having built both 383s and 440s in the past, I'd never build another stock-stroke 383 that required "good" pistons. If I had to spend the $$$ for anything beyond stock-type parts for one, it would be getting at least a 3.75"-stroke crank, too.
Good luck to the OP w/ this effort, but I believe my original post from "way back when" is still valid.
Re: New Product 383/400 Forged Piston.
[Re: mike s]
#1687002
02/03/15 03:39 PM
02/03/15 03:39 PM
Posts: 74,948 U.S.S.A.
JohnRR
U.S.S.A.
9.5-1 can be reached,depending on bore size with a closed chamber cyl hd @80cc's. 5 to 7 cc dome (off the top of my head )would allow 10.5-1.That is a very small dome that I have used before (Ross) 4.280 bore 0 [Email]deck@9.968[/Email] with 84 cc Eddies and 5 cc dome 10.7-1 .040 quench.
Curious what calculator you use , I have a 383 with a piston at zero , 3cc valve reliefs, steel shim head gasket and 80 cc heads and I'm just over 10 , I think 10.2 ?
[Re: chrisnben]
#1687003
02/03/15 03:44 PM
02/03/15 03:44 PM
JohnRR
U.S.S.A.
Keep the comments coming guys.I am exploring all piston and rod configurations.I think you will be pleased when I have the finished product to show you.I want to cover the 383-400 stock config first.I will get to the stroker and long rod configs soon if folks are interested.
Mike, any thoughts on the shorter stroker set-up lately? I'm jones'n for a piston for my 400/ 3.91 crank build here. Still looking around for a shelf piston that will get 10.5/1 up to 11/1 CR running a 78cc aluminum head. I'm first in line for the release of the Trickflow heads next month.
Chris, the piston you seek should be readily available shelf stock 4.375 bore, 1.32CH with a 5cc valve relief at zero deck and a std. .041 head gasket will get you 11.12
[Re: mike s]
#1687004
03/03/15 01:36 PM
03/03/15 01:36 PM
mike s
Mi,U.S.A.
Hi all, for a reason unknown to me my supplier has changed my deal and they have cut out most of the free options.I am now searching for another supplier. However this piston is available now.Piston will be the following a flat top,1/16 rings,CD of your choice,symmetrical valve reliefs and overbore size of .030-.040-.060.Sorry guys compression ratio will have to be modified by the cc's of the cyl head.I see that will be the only way to keep the price down. Thanks for all your support,Mike
[Re: mike s]
#1687005
03/15/15 09:02 PM
03/15/15 09:02 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I would like to see a piston at +.020... I try not to have to go straight to +.030 unless I have to.
[Re: Chris2581]
#1687006
03/21/15 04:46 PM
03/21/15 04:46 PM
mike s
Mi,U.S.A.
Chris,I now believe +.020 will be the first oversize. I want to keep the asymmetrical valve reliefs and therefore I have to drop an option. I think that will be the adjustable Comp dist. As of now the standard piston will be the following:
Bore size 4.25 +.020,030,040,060. or 4.375 for 400 block. Ring pack 1/16 1/16 /3/16 Comp dist 1.930 Asymmetrical valves reliefs or flat top w/o reliefs.
[Re: OhioMopar]
#1835788
05/28/15 03:48 AM
05/28/15 03:48 AM
mike s
Mi,U.S.A.
Hi, pistons are available from me. Only change is the valve reliefs. As of now only symetrical valve reliefs will be available.As shown in the pics posted here.Thanks,Mike
[Re: mike s]
#2382269
10/05/17 03:03 AM
10/05/17 03:03 AM
mike s
Mi,U.S.A.
In Nov.I should have my first sets of pistons from my new supplier. First up will be 383 pistons forged flat top with generous asymmetrical valve reliefs,1/16 1/16 3/16 ring size,standard 1.094 pin..Available in .+030-.+040 and.+060 over sizes.1.920 comp distance. 4032 alloy for tighter fit and quietness.
Price will be 640.00 plus shipping
[Re: mike s]
#2385309
10/10/17 10:07 PM
10/10/17 10:07 PM
Posts: 1,285 Pacific NW USA
CompSyn
Pacific NW USA
I'll be looking for replacements for 68-69 HP pistons. Ideally I'll be looking for the following: - 1.932" Compression Distance - Flat Top w/NO valve reliefs - 4032 alloy - 1.094 pin - 1/16 1/16 3/16 ring size -.+030 oversize Can I get these through you? What would they cost?
[Re: CompSyn]
#2386824
10/13/17 12:58 PM
10/13/17 12:58 PM
mike s
Mi,U.S.A.
Reality of manufacturing today is you have to compromise. I wanted to make a true 9.5-1 comp easy to get to.(pump gas) Some blocks are a bit short on deck height therefore the 1.920 comp distance. Valve notches are one item that was missing from the old standard sealed power/trw slugs.Must folks want that so they are included.I can not make every combo at this price.Overall I believe I chose the best options.The set up for comp can be tuned in with deck height and cyl hd cc's.Thanks for your interest.
Btw if anyone is interested just email me or message me here on Moparts
threerail@msn.com
Re: New product 383/400 forged piston. Now in stock!!!
[Re: mike s]
#2429787
01/06/18 04:07 AM
01/06/18 04:07 AM
mike s
Mi,U.S.A.
In Nov.I should have my first sets of pistons from my new supplier. First up will be 383 pistons forged flat top with generous asymmetrical valve reliefs,1/16 1/16 3/16 ring size, standard 1.094 pin.Press or float. Available in .+030-.+040 and.+060 over sizes.1.920 comp distance. Forced pin oiling. 4032 alloy for tighter fit and quietness.
Pistons are now in stock. They are available in .030,040 and .060 0 pin offset with 5.25 cc asymmetrical valve reliefs. Press fit or float. Forced pin oiling. Locks and Pins included. Pics soon
