New product 383/400 forged piston.
#1686955
10/17/14 06:16 PM
10/17/14 06:16 PM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
Finally a quality lightweight modern forged piston with valve reliefs for a stock stroke 383 or 400.100% American made.A true custom piston at shelf price.Comp dist will allow a zero deck @ 9.980 block height.A tall version for quench with open chamber cyl hds is being considered also.Any ring package is available.Many other options are available including high comp and alloy type. Rebalancing is mandatory due to the lighter weight. Price will be way below custom pistons.
The 64 thousand dollar question? Is there a market? Please respond with your comments either here or pm me.Mods please consider moving this to New Products and Deals post.
Leave the gun.......take the Cannoli's....Mike
Re: New product 383/400 forged piston.
[Re: Jerry]
#1686958
10/17/14 10:26 PM
10/17/14 10:26 PM
mike s
Mi,U.S.A.
Thanks for your input Jerry & Chris
[Re: mike s]
#1686959
10/17/14 10:32 PM
10/17/14 10:32 PM
moparpollack
Lil Herman
Lil Herman
85086
Mike thanks for making parts for our cars. But you never put any contact information or price for the pistons. What heads were these pistons to be used with 906, 915, 346, or stealth?
[Re: RUNCHARGER]
#1686962
10/18/14 02:37 AM
10/18/14 02:37 AM
mike s
Mi,U.S.A.
My ideas as far as compression ratios are the following. 9.5-1 is a safe maximum Iron head ratio with pump prem fuel.10.5 is easily safe for the Eddies and Stealth.
Iron factory cyl heads w/closed chamber 516/915 9.5-1 w/.040 gasket.
Iron factory cyl heads w/open chamber 906/346/452/902 9.5-1 w/.020 gasket.This piston will have a positive deck height likely +.020 w/9.980 I don't think a complete quench is possible due to non uniform factory chambers but still much better than what is available.Still working on the chamber issue.They will not have the KB quench lump.
Aluminum cyl heads with closed chamber 10.5 with .040 gasket.
A domed high compression piston will also be available in race alloy.Price will be higher but still way lower than custom prices.
All comp ratios will be figured at .000 deck height 9.980
All will be floating and press fit pins.
Your choice of ring size 5/64 or 1/16 at no extra cost.
All comp ratios will be adjustable via cyl hd cc's, Some heads may need some milling to reach the desired comp ratio.
Sorry no pricing or manufacturer (hoping to do a private label deal)info yet but price should be about the same as an Icon.
I build many low deck perf type engines and that is the reason I am trying to put this together.No more flat top TRW/SP/Fed M type no notch down the bore heavyweights.No KB cast.
If this works I will also have a legal NHRA stock elim piston. It will be as required a flat top with 1.908 comp dist (383), wo/notches and race piston material.
I await your suggestions and comments.Thank you all!
[Re: BradH]
#1686966
10/23/14 10:48 PM
10/23/14 10:48 PM
Posts: 12,415 Kalispell Mt.
HotRodDave
Kalispell Mt.
I love light weight pistons but I think the biggest market for this would be a stock weight so no balancing is required. You start buying pistons, turning your crank, balancing... and it just becomes too much for a non-stroker build Most of my customers want cheap performance. Strokers are awesome but just cost too much for most guys, on the other hand most guys can swing $2500-3000 for a 400/383 with 516 heads zero deck quench build, add a little cam and decent intake and you can build a strong stock stroke engine.
[Re: HotRodDave]
#1686967
11/05/14 03:00 AM
11/05/14 03:00 AM
mike s
Mi,U.S.A.
Update!
The first set should be ready in a couple weeks.I will post pics and specs with price then.Unlikely that this modern forging could be stock weight.But there may be a way to work that out.I am looking into that. Please continue comments and your ideas.
[Re: mike s]
#1686969
11/19/14 01:28 AM
11/19/14 01:28 AM
Posts: 8,936 Holly/MI
Dean_Kuzluzski
Holly/MI
Has anyone mentioned the idea of using a RB rod (6.76) to shorten the piston and reduce more weight?
I know the 383 already has a very good rod/stroke ratio, but this would be in the interest of reducing reciprocating mass. Or it's not worth the hassle?
[Re: blue_stocker]
#1686971
11/19/14 10:11 PM
11/19/14 10:11 PM
Dean_Kuzluzski
Holly/MI
Hey, was lookin' good until I got to........... Quote:
but they ain't cheap!
And that's why I put out in this thread. Factory "LY" rods can be had cheap.
[Re: Dean_Kuzluzski]
#1686972
11/20/14 05:08 PM
11/20/14 05:08 PM
mike s
Mi,U.S.A.
Keep the comments coming guys.I am exploring all piston and rod configurations.I think you will be pleased when I have the finished product to show you.I want to cover the 383-400 stock config first.I will get to the stroker and long rod configs soon if folks are interested.
