Wiper Linkage Grease: What to use #1685173
10/13/14 11:33 AM
10/13/14 11:33 AM
Clinton, NJ
N
njmopar Offline OP
njmopar  Offline OP
N
Clinton, NJ
Hello. What grease is the modern equivalent to what was used on the wiper linkage? The pivots have this yellowish hard grease, similar to sunroof track lube I would guess.
The motor cam/pivot had a strange grease with an almost red appearance. I thought it was rust at first, but it wasn't. I was thinking white lithium but was not sure if that would be best.
This is for an 68 a-body, if that matters.
Thanks.
Re: Wiper Linkage Grease: What to use [Re: njmopar] #1685174
10/13/14 01:51 PM
10/13/14 01:51 PM
iirc I heard something way back recommending the white lithium you mentioned (might have been what Ma used for OE). Just me I dont see a problem with some chassis grease, it'd be thick/viscous so it'd stay in place
Re: Wiper Linkage Grease: What to use [Re: RapidRobert] #1685175
10/13/14 01:55 PM
10/13/14 01:55 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I think I put some wheel bearing grease on the shafts before reassembling them. Most of it came off when the shafts were pushed through the housings. Put some Rain-X on the windshield and you won't have to use the wipers much if at all.
Re: Wiper Linkage Grease: What to use [Re: njmopar] #1685176
10/13/14 03:37 PM
10/13/14 03:37 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
Use white lithium, if you have it.
You may also want to drill a very tiny hole in the socket of the bushing to let the air/excess grease escape on assembly.
Re: Wiper Linkage Grease: What to use [Re: burdar] #1685177
10/14/14 01:21 PM
10/14/14 01:21 PM
Clinton, NJ
N
njmopar Offline OP
njmopar  Offline OP
N
Clinton, NJ
Thanks for the replies.
The only concern I have about regular bearing grease (petroleum based) is the long term impact on nylon/plastic parts. I am pretty sure lithium grease is ok.
