Compressor - Filter - Regulator (?) #1682844
10/06/14 10:11 PM
10/06/14 10:11 PM
Tennessee
WyleECoyote Offline OP
Tennessee
New abrasive blast cabinet is inbound and I want to prep for the arrival; anyone have an opinion ( ) on the best water filter / regulator combo - or individual pieces - to put in-line prior to the air getting into the cabinet?
Wile E. Coyote
Super Genius, Lover of FCA US LLC Products
68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
Re: Compressor - Filter - Regulator (?) [Re: WyleECoyote] #1682845
10/06/14 11:34 PM
10/06/14 11:34 PM
IN
ahy Offline
ahy  Offline
IN
A basic regulator/filter is a start. I use HF's "better" version.
In general, sand blasters really like dry air. The blaster may plug otherwise. A long length of metal, preferably copper, tubing with moisture trap at the end is good. A refrigerated air dryer is good also.
Desiccant type dryers work OK for spraying paint but I think they would get saturated fast with the air volume needed for blasting.
Re: Compressor - Filter - Regulator (?) [Re: ahy] #1682846
10/06/14 11:59 PM
10/06/14 11:59 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
A good basic water trap as previously mentioned, A bit down the line close to the cabinet these do very well on a budget
http://www.amazon.com/Motor-Guard-M-60-Submicronic-Compressed/dp/B000WZYKAE
Re: Compressor - Filter - Regulator (?) [Re: WyleECoyote] #1682847
10/07/14 08:50 PM
10/07/14 08:50 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
The best water separators generally will be found at the auto paint store, from what I have found. If your looking for the best. I have used the cheaper steel housing separators at home and work and they only lasted a few years for me. This one I think is a Sharp, I have Sharp spray gun also I believe and they both came from the paint store and have held up to the test of time. And they work also, just as long as your air is cool so any separator can work. Air must be cool.
Re: Compressor - Filter - Regulator (?) [Re: Challenger 1] #1682848
10/07/14 11:51 PM
10/07/14 11:51 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
I run a stand up blaster like Challenger1 showed and the Harbour Frieght cabinet and I use a rather small separater and regulater without issue. My air is not necessarily dry or cool in Florida, I take the smart little precautions, I have drops in my system, I drain the system before blasting, I make sure I use blast grade sand, I make sure my sand is dry (usually buying it the day of or just before the job), and drain the system and separater frequently during extended blasting such as when I refill the hopper or stop to let my compressor catch up/cool off.
Careful, your character's showing!
Re: Compressor - Filter - Regulator (?) [Re: Challenger 1] #1682849
10/08/14 10:44 AM
10/08/14 10:44 AM
Tennessee
Tennessee
All great tips. Thank you to everyone that posted comments. I appreciate it. I'll update with pics when I'm done with installation.
Wile E. Coyote
Re: Compressor - Filter - Regulator (?) [Re: WyleECoyote] #1682850
10/08/14 04:41 PM
10/08/14 04:41 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I ran 40 feel of galvanized pipe on my wall with a short flexible hose hooked to my compressor. It has a down tube and a ball drain at both ends. It zigzags up the wall to the ceiling and then straight down to a drain. This gives the hot air a chance to drop its moisture as it cools. All parts of the pipe are angled to let water drain to one side or the other.
Another piece of galvanized pipe jogs up at the final down leg about mid-pipe and goes into a water separator. Its never even gotten one drop of water in it after 7 years, because the galvanized pipe dries the air and the collected water falls down to both ends of the drains.
I found the idea for this on Google.
Re: Compressor - Filter - Regulator (?) [Re: jbc426] #1682851
10/08/14 04:44 PM
10/08/14 04:44 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Here's the other end. The air comes out a dry as a popcornfart every time, all the time. Catches a lot of water at the ball valves.
