Re: Seriously??? I have to do WHAT to change a thermostat??
[Re: 98RAM1500]
#1682794
10/06/14 09:43 PM
10/06/14 09:43 PM
Posts: 27,728 places
79powerwagon
places
I don't know the truck's history much past it was a one-owner truck, and the garage I bought it from did a bunch of routine maintenance before putting it up for sale (for charity). I got it last month. I also found a video on YouTube on this subject, and it looks like I can simply remove the belt and alternator to get the access I need, not the whole shebang. Thanks guys!
[Re: 79powerwagon]
#1682797
10/07/14 01:47 AM
10/07/14 01:47 AM
Posts: 5,998 Salem
Grizzly
Moparts Proctologist
Salem
79powerwagon: It's not as big of a job as it looks. I did it on my 360 Magnum and had the same initial reaction as you. Turned out, it wasn't so bad.
Mo' Farts
Moderated by "tbagger".
[Re: Grizzly]
#1682798
10/07/14 10:22 AM
10/07/14 10:22 AM
Posts: 12,494 Western Colorado High Desert
moparmarks
79powerwagon:
Yep, just take a good hard look at it and use you imagination. You don't need to remove the accessory mount. I've done it several times on the V8's and once on the V6
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: moparmarks]
#1682799
10/07/14 03:33 PM
10/07/14 03:33 PM
Posts: 12,415 Kalispell Mt.
HotRodDave
Kalispell Mt.
You can change it with a long needle nose pliers and some patience without pulling anything else cept maybe the little flat steel bracket. If you want to put a screw type hose clamp on pull the alt out of the way. I have worked on hundreds of the magnum motors and never seen a bypass hose leaking timing covers, yes, t-stat housing yes, intake yes, bypass hose never. Seems they used a lot better rubber than the 92 back 360 91 back 318
[Re: HotRodDave]
#1682800
10/07/14 09:58 PM
10/07/14 09:58 PM
Posts: 21,059 Niles , Ohio
therocks
Niles , Ohio
If you think thats bad you better not buy any much newer.Just did the 99 360 and its about the same thing.Did the wp and by pass also when we did the intake.Not a bad job and looks worse than it is.I do have tools though as I was a tech for 30 years.Rocky
Chrysler Firepower
