'98 Ram headlights #1682152
10/05/14 11:34 AM
10/05/14 11:34 AM
South-east Mn
blaze Offline OP
blaze  Offline OP
South-east Mn
I went to leave a friends house last night, pulled the light switch, no headlights. Drove about 2-3 miles, and they came on. Dimmer switch? Headlight switch in the dash?
Re: '98 Ram headlights [Re: blaze] #1682153
10/05/14 03:03 PM
10/05/14 03:03 PM
Crockett ,TX
9
98RAM1500 Offline
98RAM1500  Offline
Crockett ,TX
Its the Headlight switch
Re: '98 Ram headlights [Re: blaze] #1682154
10/05/14 09:01 PM
10/05/14 09:01 PM
Chicago illinois
ChinooK440 Offline
ChinooK440  Offline
Chicago illinois
It could be the wiper switch /hi/low beam switch ... try clicking the hi beams on and off and hold it / keep it pulled back and see if the lights stay on or flicker on and off .
Re: '98 Ram headlights [Re: ChinooK440] #1682155
10/06/14 12:04 PM
10/06/14 12:04 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
....seen it before. Might just be a tad bit of corrosion/debris in there. Click the high/low beams back and forth about 10 times and see what happens.
Re: '98 Ram headlights [Re: blaze] #1682156
10/06/14 01:15 PM
10/06/14 01:15 PM
Franklin Square, NY
CUDAAR Offline
CUDAAR  Offline
Franklin Square, NY
The headlamps in my 97 Ram SST would shut off every time I tilted the steering column down. It was once repaired while still under warranty but started acting up again when the warranty expired. I found that the headlamp wire going into the directional/hi beam switch would pull itself out when tilted down & then plug itself back in when tilted back up. I wound up splicing in a new wire because the old one would not "snap" in place & stay connected.
-Lou
Re: '98 Ram headlights [Re: CUDAAR] #1682157
10/13/14 11:10 PM
10/13/14 11:10 PM
Way out in the sticks of Weste...
DusterDog Offline
DusterDog  Offline
Check the plug at the H/L switch also.
The one on my 98 was melted to the point that it wouldn't make contact at the switch.
"I've upped my horsepower, so...... UP YOURS!!!"
Re: '98 Ram headlights [Re: DusterDog] #1682158
10/19/14 10:28 PM
10/19/14 10:28 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
on my '95 Dakota, new headlight switch + old overheated harness = another burned up headlight switch. Both switch and plug need to be replaced if they got really hot.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
