FUEL CELL, SHOULD I RUN -8 OR -10 FITTINGS #167662
12/14/08 08:50 PM
12/14/08 08:50 PM
alabama
mopars rule Offline OP
mopar addict
mopar addict
alabama
I have a 5 gallon fuel cell that came with -8 AN fittings in it. At what point does it become necessary to run a -10 AN?
Re: FUEL CELL, SHOULD I RUN -8 OR -10 FITTINGS [Re: mopars rule] #167663
12/14/08 08:58 PM
12/14/08 08:58 PM
Probally around 1000 hp total using power adders or on straight motor, but I don't really know as all of my junk makes less than that and I use a single # 10 to my 300 GPH pump, which is suppose to be good to 900 hp two number eights with the right system should be good to 1000HP + I would think, maybe not Try calling a couple of the companys that make good fuel system parts and ask them
Re: FUEL CELL, SHOULD I RUN -8 OR -10 FITTINGS [Re: Cab_Burge] #167664
12/14/08 09:01 PM
12/14/08 09:01 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I would say it depends on what system you plan on running. on a deadhead regulator I run 8 from the tank to the reg then 6 to the carb. this has worked on 600hp with no problems.
Re: FUEL CELL, SHOULD I RUN -8 OR -10 FITTINGS [Re: mopars rule] #167665
12/14/08 09:04 PM
12/14/08 09:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I run a pair of #8s to a pair of the 150 Holley
black pumps then to a Y then a #10 forward to the regulator then
a #8 to the carb , a #8 return line. This winter
I
will change the #8 to the carb to a pair of #8s to
the carb
Re: FUEL CELL, SHOULD I RUN -8 OR -10 FITTINGS [Re: Quicktree] #167666
12/14/08 09:06 PM
12/14/08 09:06 PM
alabama
mopar addict
mopar addict
alabama
BG 280 pump with internal bypass, then to a filter with stainless mesh. This is a small block duster that for now will only run mid to low 7's in the 1/8 mile. Fastest it will probably ever go will be 6.00 in 1/8 th.
Re: FUEL CELL, SHOULD I RUN -8 OR -10 FITTINGS [Re: mopars rule] #167667
12/14/08 09:09 PM
12/14/08 09:09 PM
Q
Quicktree Offline
Quicktree  Offline
Q
a holley blue pump deadheaded with #6 would handle that. you are way on over kill.
Re: FUEL CELL, SHOULD I RUN -8 OR -10 FITTINGS [Re: Quicktree] #167668
12/14/08 09:16 PM
12/14/08 09:16 PM
alabama
mopar addict
mopar addict
alabama
So in the future a -8 line from cell with BG 280 pump and -8 all the way to regulator at carb then -8 from regulator to carb would support a say 440 to 500 cube motor running 6.00 in the 1/8 th.
Re: FUEL CELL, SHOULD I RUN -8 OR -10 FITTINGS [Re: mopars rule] #167669
12/14/08 09:20 PM
12/14/08 09:20 PM
Q
Quicktree Offline
Quicktree  Offline
Q
so you are by-passing at the pump? that should be plenty imo. Iam not up on the bg crap though.
Re: FUEL CELL, SHOULD I RUN -8 OR -10 FITTINGS [Re: Quicktree] #167670
12/14/08 09:27 PM
12/14/08 09:27 PM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
-9
Re: FUEL CELL, SHOULD I RUN -8 OR -10 FITTINGS [Re: CokeBottleKid] #167671
12/14/08 09:31 PM
12/14/08 09:31 PM
alabama
mopar addict
mopar addict
alabama
Re: FUEL CELL, SHOULD I RUN -8 OR -10 FITTINGS [Re: mopars rule] #167672
12/14/08 09:33 PM
12/14/08 09:33 PM
Toronto Ontario, Can
Glen440 Offline
Glen440  Offline
A BG280 with -8 line supports my 700hp engine no probs.
87 dakota 6.1 hemi
Re: FUEL CELL, SHOULD I RUN -8 OR -10 FITTINGS [Re: Glen440] #167673
12/14/08 09:37 PM
12/14/08 09:37 PM
alabama
mopar addict
mopar addict
alabama
Guess I will be fine with mine then because it will be a long long long time before I see those HP numbers in my car. The reason I got such a big pump was I got a heck of a deal on it from a member here.
Re: FUEL CELL, SHOULD I RUN -8 OR -10 FITTINGS [Re: mopars rule] #167674
12/14/08 10:32 PM
12/14/08 10:32 PM
Saskatchewan, Canada
cudabin Offline
cudabin  Offline
Single 1/2" aluminum hard line to a single holley blue pump with two -6 lines from the deadhead regulator to the carb works fine for us!
Runs 9.50's at 144 mph and 6.0's in the 1/8 mile.
Pulls hard all the way through the quarter.
Everyone will tell you you need more pump, but this seems to work...
B-1 Ken used to do the same with a single holley Blue pump...
Cheers,
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...) 70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
Re: FUEL CELL, SHOULD I RUN -8 OR -10 FITTINGS [Re: cudabin] #167675
12/15/08 12:13 AM
12/15/08 12:13 AM
SE Michigan
farmington Offline
mopar addict
farmington  Offline
mopar addict
SE Michigan
when Bob Glidden won Pro Stock in his Plymouth Arrow (1978?) he used 2 blue Holley pumps on his car.
Re: FUEL CELL, SHOULD I RUN -8 OR -10 FITTINGS [Re: farmington] #167676
12/15/08 12:39 AM
12/15/08 12:39 AM
When bob Glideen won that tital that was the only choice, no black pumps, no decent Mallory or any other brands of electric fuel pumps, if I remember correctly
Re: FUEL CELL, SHOULD I RUN -8 OR -10 FITTINGS [Re: Cab_Burge] #167677
12/18/08 12:02 AM
12/18/08 12:02 AM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
-12 out of the tank to the pump , -10 to the reg , -8 to the carb . B/G 400 pump and matching reg .
Chryco
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: FUEL CELL, SHOULD I RUN -8 OR -10 FITTINGS [Re: mopars rule] #167678
12/18/08 09:52 PM
12/18/08 09:52 PM
NC
440Jim Online work
440Jim  Online Work
NC
There are two groups on the fuel pump/system question...
Big and just enough.
I run two #8 lines out of the cell to a Y-block, short pipe (.4" ID) to my fuel pump. Then 1/2" aluminum line up front to the regulator. Then two #8 lines from the regulator to the carb (over kill IMO). Times in the sig.
Post deleted by Defbob [Re: 440Jim] #167679
12/18/08 10:19 PM
12/18/08 10:19 PM
Re: FUEL CELL, SHOULD I RUN -8 OR -10 FITTINGS #167680
12/18/08 11:22 PM
12/18/08 11:22 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
You can't put in too big of a primary fuel line. I say go with the -10.
I run -12 to prostar 500,-10 to the reg,-8 to carbz
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: FUEL CELL, SHOULD I RUN -8 OR -10 FITTINGS #167681
12/19/08 12:03 AM
12/19/08 12:03 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
