merge collectors
#1676607
09/24/14 08:30 PM
09/24/14 08:30 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
how much horsepower or improvement in ET have you guys seen switching from the conventional collector to a merge collector
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
Re: merge collectors
[Re: WHITEDART]
#1676608
09/24/14 08:51 PM
09/24/14 08:51 PM
Posts: 52,972 Romeo MI
MR_P_BODY
how much horsepower or improvement in ET have you guys seen witching from the conventional collector to a merge collector
This might be a hard question to answer.. a TRUE merge collector HAS to be designed for a certain engine.. but from the little bit I know about merge collectors that COULD be as high as 25-30 hp.. again.. if designed for that engine.. the diameter on the inlet, taper rate and max diameter then the taper rate down to exit diameter... its much like a 2 cycle expansion camber... do it wrong and you move the power range way down or way out of the rpm range... I played with them on the dyno and finally gave up with what I was playing with... so to just buy a merge collector off the shelf is wasting your time and money... JMO
[Re: WHITEDART]
#1676612
09/24/14 11:30 PM
09/24/14 11:30 PM
Posts: 13,185 aZLiViN
J_BODY
aZLiViN
Greg built my headers with a merge set up. for the cost of a regular collector you can bet we'll be playing with it...... someday. I seem to find alot of other things to do other than work on the car.
[Re: BradH]
#1676614
09/25/14 04:08 PM
09/25/14 04:08 PM
Posts: 2,915 A shed in England
Tig
A shed in England
We swapped out some home built, crappy mild steel 2 1/4 with 4 inch collector for some custom, $2500, Stainless, 2 1/4 equal(ish) length with 4 inch merge collectors. Et's and MPH never changed a bit but they sure looked a lot better
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#1676616
09/25/14 05:18 PM
09/25/14 05:18 PM
MR_P_BODY
Thats the time about headers and the merge collectors.. it has to be matched to the engine and the rpm that it will be at MOST of the time... I did header work at Chrysler for about 15 years and near the end I was playing with merge collectors... but the merge coll wants to be in a certain rpm range most of the time.. thats why the pro stocks use them.. they dont vary a ton in rpm like a lot of other engines... I put about 40 hours into merge collectors on the dyno to come up with a formula but I never really got there
