2011 Durango with trailer turn signals/hazards not work #1675226
09/21/14 04:35 PM
09/21/14 04:35 PM
WASHINGTON, PA
11secaarcuda Offline OP
WASHINGTON, PA
I just put a factory hitch on my 2011 Durango, and it had the wiring harness already on it, I just had to splice the 7 way pigtail at the rear and then plug in the brake controller up under the dash. The turn signals and hazard flashers will not work. Everything else is working fine. Is there a separate circuit I have to tap into to get the turn signals and hazard lights to work on the trailer?
67 Dart GT 340 4 speed
70 AAR Cuda 408 6 barrel
96 Indy Ram original owner
2011 Hemi Durango
Re: 2011 Durango with trailer turn signals/hazards not work [Re: 11secaarcuda] #1675227
09/21/14 05:43 PM
09/21/14 05:43 PM
Ohio
Todd Offline
Todd  Offline
Ohio
If you added the hitch then I don't ever remember them being already wired with a trailer plug.
If it was wired correctly (with a Mopar harness)
Then the sales code needs to be added to the build configuration so the TIPM turns on the circuit.
Re: 2011 Durango with trailer turn signals/hazards not work [Re: Todd] #1675228
09/21/14 07:44 PM
09/21/14 07:44 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
....What he says.
Even when installing a Mopar Fog Light system, the vehicle needs to have the circuit in the TIPM (Totally Integrated Power Module) enabled or the lights won't work.
Probably should go to the Dealer to have this done.
Re: 2011 Durango with trailer turn signals/hazards not work [Re: superwrench] #1675229
09/22/14 12:49 AM
09/22/14 12:49 AM
WASHINGTON, PA
WASHINGTON, PA
thank you, I'll have it done next time it goes in for service. I will probably only tow once this year anyway.
2011 Hemi Durango
