Can't find any info on a block casting # #1671086
09/14/14 11:34 PM
09/14/14 11:34 PM
Pittsburgh PA
Eric Offline OP
Eric  Offline OP
Pittsburgh PA
3830830-400-5
Anyone?
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Can't find any info on a block casting # [Re: Eric] #1671087
09/15/14 12:36 AM
09/15/14 12:36 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What are you trying to find out ?
Re: Can't find any info on a block casting # [Re: Eric] #1671088
09/15/14 12:43 AM
09/15/14 12:43 AM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
According to the experts, the sand casting core box, is on it's 5th revision.
Re: Can't find any info on a block casting # [Re: Leigh] #1671089
09/15/14 01:05 AM
09/15/14 01:05 AM
Pittsburgh PA
Eric Offline OP
Eric  Offline OP
Pittsburgh PA
Year?..if it's any good? Sonic checked very good for what it's worth.
Re: Can't find any info on a block casting # [Re: Eric] #1671090
09/15/14 01:13 AM
09/15/14 01:13 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Eric .. if you have the Mopar big engine book it'll
tell you the year(mine is out in the shop) but it wont
tell you anything other than that.. if it sonic checks
good then I would think its a good block
Re: Can't find any info on a block casting # [Re: Eric] #1671091
09/15/14 01:39 AM
09/15/14 01:39 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
The last number 5 does mean its on its 5th casting, that doesn't mean its bad. For the year, its cast right into the block right below the casting numbers on the drivers side at the rear of the block below the heads on your engine block. Other years , its on the passenger side.
But with your numbers as posted it should be on the driver side. Reguardless, the year stamping numbers will be cast into the block. Look , both sides. Should be very visable, but maybe not super readable.
Re: Can't find any info on a block casting # [Re: Sport440] #1671092
09/15/14 04:02 PM
09/15/14 04:02 PM
dogdays Offline
dogdays  Offline
The dash number means diddly.
There is no correlation between dash numbers and casting quality.
The Mopar blocks are all over the map in terms of quality, they were all good enough to get a stock car to 100,000 miles and that's what they were built for.
The UT numbers are the really important ones for a particular block. Casting numbers are secondary.
R.
Re: Can't find any info on a block casting # [Re: Eric] #1671093
09/15/14 04:39 PM
09/15/14 04:39 PM
AndyF Offline
AndyF  Offline
That casting number isn't in the GG book that I have which seems odd. I haven't found many castings that aren't in the GG book.
I assume that it is a 400 block? A 38xxxxx part number would be from the late 70's which makes sense.
There will be a casting date on the other side of the block, a VIN on the oil pan rail and some ID information on the ID pad under the distributor. Between all the other numbers you should be able to nail down what the block is.
Re: Can't find any info on a block casting # [Re: AndyF] #1671094
09/15/14 04:44 PM
09/15/14 04:44 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
There were a ton of crate short blocks that were warranty replacements that did not have a casting year visible.Look for a rivit hole above the pan rail on either side where a tag was attached.
Re: Can't find any info on a block casting # [Re: Eric] #1671095
09/15/14 11:01 PM
09/15/14 11:01 PM
Lehigh Acres, Florida
rickstershemi Offline
Anyone?
1972 - 1980
Rickster
