Re: ProMaxx Performance 440 heads
[Re: young guns 90s]
#1654595
08/03/14 09:20 PM
08/03/14 09:20 PM
Posts: 403 Romulus, MI
GTS340
Romulus, MI
any buddy use ProMaxx Performance 9440 - ProMaxx MAXX Series Big Block Chrysler Aluminum Cylinder Heads Details
Big Block Chrysler 210cc/295+ CFM Additional Cylinder Head Specifications Valve Angle: 15° Valve Seal Material: Viton Spark Plug Type: Angled Retainer Material: Steel Maximum Spring Lift: .600" Hydraulic Flat Tappet think about use them on 66 440 factory steel crank factory steel rods lighten polish with JE or ROSS pistons full floating pins
Looks a lot like Edelbrock Performer RPM 440 head. I wonder if it's just Promaxx working a set of the sidewinder castings?
[Re: jamesc]
#1654599
08/03/14 09:55 PM
08/03/14 09:55 PM
GTS340
Romulus, MI
i'm not certain but looked around a little bit and am inclined to believe they're imported castings, i could be wrong. that said if they are imported for that money i'd pony up the rest and buy a USA made head but that's just me. they actually cost more than the 75cc e street heads with the racer discount
You have a PM
[Re: jamesc]
#1654601
08/03/14 10:29 PM
08/03/14 10:29 PM
Posts: 13,185 aZLiViN
J_BODY
aZLiViN
#1654602
08/03/14 10:33 PM
08/03/14 10:33 PM
Posts: 3,395 Pa
Hot 340
Pa
for price cant beat it
how could you possibly know this without running them?
[Re: Dunnuck Racing]
#1654604
08/04/14 12:39 AM
08/04/14 12:39 AM
Posts: 914 tn
robnbird
tn
Promaxx doesn't buy castings from the guys selling Sidewinder heads, that much I know. RPM heads and Stealth heads both flow much less than advertised on a calibrated bench. Sidewinder heads will out flow those two castings out of the box. I don't know how these Promaxx compare Keith
where can they be bought .
#1654606
08/04/14 01:15 AM
08/04/14 01:15 AM
Posts: 914 tn
robnbird
tn
The Sidewinder heads can be bought through Todd at CompWedge Engines, or I can get them. There are a couple other builders selling them also . They really are a nice part . I have a build in the works with a set now. More consistent port shape and size when compared to other brands I have used. Keith
how are these compared to the Eddy victor max wedge ?
[Re: sasquatch]
#1654608
08/04/14 01:43 AM
08/04/14 01:43 AM
Posts: 914 tn
robnbird
tn
Guys as far as I know the Promax and the sidewinder are the same casting. Robin they will not touch a Victor. These are much more akin to the RPM. Todd
OK thanks Todd , I am going to order the eddy max wedge tomorrow but going to use the Indy 400-3 intake .
[Re: DusterDog]
#1654612
08/08/14 02:29 AM
08/08/14 02:29 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
So...are these gonna stick around longer than the BullDog heads?? Or just the next flash in the pan.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: Blown 68 R/T]
#1654614
09/30/14 07:49 PM
09/30/14 07:49 PM
Posts: 3 Ky
Skynyrd
Ky
I purchased mine from Hensley Racing . About two months ago. Makes great power. Had a medium Port job done. Ken Hensley said they flow better than similar aluminum heads. Rpm etc. Before any work. I have the full Info. Somewhere. 74 Plymouth Duster , 312/590 mopar purple cam. Forged pistons, h beam rods. 1050 dominator. Hooker super comp. Headers. 440 30 over. After about 20 1/8 runs Low 6.50s. I don't think it's realizing full potential yet. Made in USA.
[Re: DGS]
#1654617
10/01/14 09:08 AM
10/01/14 09:08 AM
We recently did a maxed out full port on the Sidewinders ( same head I believe) and the results were right at 313 CFM intake on a Very correct , calibrated, stingy bench. I am sure as time rolls on and more heads are whittled on that it will get better but honest, this is a street strip head not intended to go toe to toe with Victors, Indys etc It is designed to be an Edelbrock killer and I guess you need a "Sidewinder" to shoot at Stealths? So far---I have done several strong street engines with these heads --ZERO issues--I love the casting quality and the seats and guides are some of the best on the market --ports are more equal on these than other brands as well. We have a regular old 440 flat top headed to the dyno soon with a set and a hyd cam so will report. I love the quality for the $$ and feel like they are the best answer out there for a street/strip big block--way less than Edelbrocks and IMO better overall quality than everything else. Want to race hard and go really fast? Sure, there are better choices but these heads will do anything an Edelbrock Performer head can for LESS $$ and at 313 CFM--Surprise many a bracket racer!! Now...spending the loot it takes to get 313 CFM range--on a street head? Well... that is up to the individual, and a real race head may be better choice but...the heads are VERY capable of some Serious HP! So far....I LOVE these heads!
[Re: DGS]
#1654621
10/01/14 03:13 PM
10/01/14 03:13 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I believe in either this month or last months Mopar Muscle they did a 451 build and use the ProMax heads. I dont remember all the details but I think they flowed around 340 on the intakes ? I know the eng made very good hp (like 675 I think) and torque. I will try to look it up when I get a chance. Ron
They used ProComp heads (Victor copy?): http://www.moparmusclemagazine.com/techarticles/1411_randy_maliks_452ci_low_deck_wedge_mopar_engine/
Opps. Thanks for the correction. Sorry about that. Ron
[Re: hudsonhornet7x]
#1654623
10/01/14 07:22 PM
10/01/14 07:22 PM
BradH
What do out of the box standard port victors flow? I know they are designed for something different than sidewinders but how do they compare?
"It depends..." It's not just variance between castings, but also the last generation Victors that came out in late 2011 (IIRC) got a better designed chamber (in theory), but a more restrictive intake port that is nowhere near as good as the original version in terms of basic flow #s.
The Procomps in the article linked above are seriously NOT stock, between MCH's CNC MW porting, plus Malik's filling of the port floor, etc. I've got a Procomp I've used as a "crash test dummy" for some porting and with a good valve job and an otherwise stock casting flowed 310-315 IIRC. I've done some basic porting while keeping pretty close to a standard port entry (nowhere near MW size) and pushed them to 340+ at .700". There are some old threads on here from right about a year ago where I posted those results, FWIW.
[Re: dogdays]
#1654624
11/05/14 06:38 PM
11/05/14 06:38 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Remember a few years ago, a new US cylinderhead company called Patriot? They staked out the lower edge of the smallblock chevy market, made a decent aluminum head which got a lot of press because it was good but inexpensive.
Somewhere along the way they were bought and renamed as ProMaxx.
As their sbc and sbf heads were pretty good, I would guess that their BBM heads would be good too.
R.
^^^^^^^^^^This. ProMaxx, formerly Patriot Performance is located in Rainbow City Alabama. Been there a long time and is not going away anytime soon. Before it was Patriot, it was Alabama Cylinder Head, which has been in business for decades. When they moved more focus towards performance, it was renamed Patriot by then owner and before that, long time employee, Marty Witt. The company was recently sold to another individual, who changed the name to ProMaxx, but all the same people, including Marty Witt, still work there. All machine operation are done in house in Alabama and they have some very nice and very up to date equipment, with guys who can run it.
Monte
[Re: RAMM]
#1654631
11/09/14 12:02 PM
11/09/14 12:02 PM
Posts: 4,763 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Why do most mfgrs of aluminum heads have the ends milled flat and polished? Is this to have a clear and readable logo?
Keep old mopars alive.
[Re: 2boltmain]
#1654632
11/27/14 12:36 PM
11/27/14 12:36 PM
Posts: 1,412 Johnstown
69dart
Johnstown
Jegs has these heads ON SALE today. JEGS I may have to try a set at those prices!!!
[Re: 69dart]
#1654634
12/12/14 10:38 AM
12/12/14 10:38 AM
Posts: 3 Ky
Skynyrd
Ky
Does anyone know if the pushrod clearance is any better on these than the 440Source Heads? We had several hours of grinding to get the pushrods to clear on my 383.
Yep, several had to be filed. That was an unexpected deal. I don,t remember what size pushrods we used without looking on the build sheet . But we stuck with the largest size , was told to not go to the smaller one's. I thought maybe we needed offset rockers but that may not be right.
[Re: Skynyrd]
#1654635
12/12/14 12:34 PM
12/12/14 12:34 PM
Making room for push rods is normal on any aftermarket head unless you use a 5/16ths--which with hyd cams is fine-- but most builds will require a 3/8ths pushrod--any Mopar requires lots of time spent--shimming each pair rockers--getting it just right--centered on valve as close as possible while clearing the head and all the while winding up with proper side clearence per pair on rockers--each pair may be shimmed different--that is Normal--grinding for more room is very normal operation an any build. Wait until you get smart and put 1.6 ratio rockers on with a big cam--Lots o grinding there!! I have been dynoing plain old 440 street engines with Sidewinder heads--looks like with bigger hyd cams they are doing easy 530 range on simple flat top pump gas combos--these have been with STAMPED stock rockers as well. Low you say?? I say cheap and simple and enough HP and monster TQ to rip quarter pannels off. 90% of customers have NEVER had any real HP and over 500 REAL HP makes them shake after a ride--as it SHOULD! The quest for all these 600-700HP street engines is a laugh to me--you can't hook it up--they are a PIA to drive with all that converter , gear etc--Street driving a race engine has never been as fun as it is rated--like driving the Zamboni on a skating rink. Just my two cents worth--Call Todd at Marsh, get some Sidewinders and enjoy not paying the extra $600 for Edelbrocks and going same speed. Same head everywhere no matter the name--buy a skid of them and you can name them anything you want--we are LUCKY to have a quality head that is less than the others out there--Source heads are brittle castings to me--these heads have the guides centered Right ON and are all CNC finished--I have been using them like popcorn and Todd at Marsh Performance has Kept them coming!!!!
[Re: Thumperdart]
#1654637
12/12/14 04:32 PM
12/12/14 04:32 PM
Man I must be getting old... No..wait a minute, I just built a vintage Front Engine Dragster...oh wait, now I am old and Crazy!! I just got tired of dodging the deer and the cops on the street and now with all the texters driving , I am WAY safer at the track. You go Thumperdart! I admire you!!!!!!!!!!!
[Re: ]
#1654641
01/07/15 03:29 PM
01/07/15 03:29 PM
BradH
... The quest for all these 600-700HP street engines is a laugh to me--you can't hook it up--they are a PIA to drive with all that converter , gear etc--Street driving a race engine has never been as fun as it is rated--like driving the Zamboni on a skating rink.
Well, my car drove pretty much the same on the street when it ran 10.5s as it did when it ran 12.0s. Not just my opinion, but that of a friend of mine who has seen the car evolve over most of the last 20 years I've owned it.
I don't race on the street, but if I wanted it to hook on the street( ), I'd take a different approach than what I've done to date.
You may now return to your regulary scheduled program about these new budget heads.
[Re: BradH]
#1654642
01/07/15 07:04 PM
01/07/15 07:04 PM
I should have said Most not all Sure there are guys that have evolved a car/combo over the years and it is what hot rodding is all about--That is a thing of beauty and to be admired I just see so many combos that are not that well organized or sorted and are really just race car set ups on street car paint jobs and thus my statement--BTW I built a few of the unruly type when I started-- These days FI etc has sure made things better and all the big CI with mild cam and 3.23 rear gears --sweet new converter science--all adds up to some magnificent street machines that will run as well as our race cars did 20 years ago again.... On the street I prefer my Hemi Ram pick up and on the track I am LOVING my Front engine dragster--Both do what is asked of them really well After a pass in the dragster you KNOW you were in a race car that was stinking fast--and the truck has comfortable room for all the junk I carry around with me and a big console storage
[Re: ]
#1654643
01/08/15 09:05 AM
01/08/15 09:05 AM
Posts: 3 China
Stevenisme
China
A young guy who involved in OE engine parts for 7 years, sold his building, rent a apartment, live with his wife and 2 years old baby. The money was invested in casting and CNC machines which is same as the former OE factory. The quality is this young guy's face and future. They have no sense of how to make cheap aftermarket heads. Such as T6 heat treatment could be 5 hours or 3 hours, the hardness could be same, it was not what casting standard told me, it was a aftermarket casting guy told me. I don't think Promaxx or Sidewinder heads need to shoot at Stealth head. Stealth head was casting from one factory, machining by another factory. I know these two factory people since 2010. If you put Promaxx or Sidewinder head with Stealth head, you will make the decision in a half second. The Mopar heads need some fresh blood to let people know the heads could be better done. Quote:
[Re: dogdays]
#1654645
01/12/15 06:16 AM
01/12/15 06:16 AM
Posts: 636 Graz, Austria
DGS
Graz, Austria
So now that we're talking to someone much closer to the manufacturer, here's the question I've been dying to ask: Could you build a head with a modern combustion chamber? Look at the AFR smallblock chevy heads for inspiration. Or basically any other modern aftermarket Wedge head.
Thanks, R.
The discussion always seems to stop when the topic gets to the old chamber design..
[Re: DGS]
#1654646
01/12/15 11:31 AM
01/12/15 11:31 AM
Those chambers usually come in at 75CC range or less I am sure as an aftermarket maker they have to decide--will these heads work with all the pistons and combos out there already--I think that is the consideration--OK you get the small chamber and now everyone will start needing dish pistons for the street stroker combos--it will be a challenge of sorts to get correct CR for street--Do you really think that chamber is going to add anything more than a tenth or so? It sure won't be a five car length deal in most cases now will it? The Sidewinders are an EASY to use head that is high quality and cheap--better quality by FAR than the previous low price leader--I say again--BY FAR! It works super easy with shelf stock ( read less expensive) pistons and is like an Edelbrock in terms of power making ability ( if not better) so I love them. If I want a race head well..I can deal with Indy--wait....I would rather go slower. BTW just got a set of new SR indys--the deck was cut with three passes using a narrow cutter---now who in the world thinks that is a good idea?-deck had at least a two thou "step" at each of these lines--and the valve job had so much chatter in it--looked like the cutter used was from 2006 so....after spending time and $$ to clean that mess up I am even more convinced that these Sidewinders are good enough for the large percentage of my builds These heads are a good thing--I could care less about a closed chamber version--that is not what they are aimed at.
[Re: 67Satty]
#1654649
01/25/15 12:22 PM
01/25/15 12:22 PM
Posts: 3 China
Stevenisme
China
Crabman and Dunnuck, I know each engine could be different, but in general, what is the pushrod clearance like with these heads and 3/8" pushrods and 1.5 rockers? Have you had to grind for clearance or not had to grind for clearance in most cases? Thanks!
I did not hear anything about the clearance. If there is before, there is not afterwards.
[Re: 69dart]
#1654651
03/25/15 11:34 PM
03/25/15 11:34 PM
I have done three engines with 3/8ths pushrods so far--no grinding needed BUT--I did take my time and shim each pair around like you always have to do on Mopars--these were all rollers as well Maybe you need a touch here and there--it would be a big plus to have just a tad more room then it would be for sure but I think any engine builder that knows his way around a Mop will have almost no trouble with 3/8ths--
[Re: ]
#1654652
03/29/15 01:31 PM
03/29/15 01:31 PM
69dart
Johnstown
Sounds good. I'm still waiting for the UPS guy to drop them off . I'm curious of how much shim is typically needed? I finally tested the shims on my current setup and the .030 shim got it centered. Fingers crossed this and solid spacer rather than springs cures my broken rocker issues.
[Re: Stevenisme]
#1654654
03/30/15 09:10 PM
03/30/15 09:10 PM
Steve I am doing one later this week on a 440 with 3/8ths pushrods and a .575 solid roller with Harland Sharp 1.5 ratio rocker arms I will let you know how it works out
[Re: Streetwize]
#1654656
03/31/15 10:06 PM
03/31/15 10:06 PM
We have been usingthem like popcorn--so far have done everything from swap them on a 440 with 509 hyd--wowzer--out of the box stamped rockers GREAT engine---- to some port work , 440 ,big hyd cam and an EASY 569HP first pull--full ported are showing better and better numbers as Larry zeros in on them--I have a set on a 511 right now that I just cleaned up on my back yard bench--street solid roller --will report as it moves along--not pulling every angle just tossing it together and see what happens-- So far with 1.5 PRW rockers and 3/8ths push rods I had them all clear on a street hyd roller unit--have Harlands on this 511 so we'll see soon as Smith gets the tubes here
#1799674
04/09/15 07:50 PM
04/09/15 07:50 PM
69dart
Johnstown
Heads were delivered today. Pluses They look really nice... a very nice finished look Bowls and exhaust ports look perfect Very little cleanup left to do OOTB Minuses Need a little cleanup to match the intake ports Stamped locks so those will have to go Doesnt look like any of the holes are helicoiled so hopefully that wont be an issue I've ran 906's, Edelbrocks and 440 Source Stealth so far and would say the new ProMaxx Heads look very promising at an unbelievable price point. Once I get the intakes port matched and clearance the pushrod holes a bit for good measure I'll get to my engine builder to see what he thinks. I see 5.90's in my future
[Re: 69dart]
#1799802
04/09/15 10:22 PM
04/09/15 10:22 PM
crabman173
crabman173
3/8ths pushrods cleared with PRW stainless rockers--They will NOT clear with Harland Sharp 1.5's I worked and worked but was afraid of boring through an intake wall or worse so I quit and ordered Smith Bros 5/16ths pushrods for this 511 Smith says good for 700 open I got 460 range so am not worried about that part They clear ok at the bottom but up near the top it was trouble The Smith Brothers 5/16ths are my go to for this issue on street engine now--Geeez! I am getting too old for this I need a career change Steven in China Listen up!
#1799838
04/09/15 10:58 PM
04/09/15 10:58 PM
Posts: 1,807 North Dakota
Azzkikrcuda
North Dakota
I have been using the thick 5/16 from Smith Brothers on a few street engines. They work great, and I don't have to mess with clearancing the head.
The only Carbs I care about are under the hood!
#1799851
04/09/15 11:09 PM
04/09/15 11:09 PM
crabman173
crabman173
I actually sent for the .080 wall as they assured me they were stout enough they also had the .120 wall but -----he said they might make me sleep better but that at my 9 inch length the 080 was rated at near 700 open--I figured they knew and so... They do look like the future as far as I am concerned
#1873354
07/19/15 08:35 AM
07/19/15 08:35 AM
crabman173
crabman173
1.6 ratio is always a PIA on any Mopar head The Sidewinders are a bit fatter at the top of the intake port--I have had to do more on them than other heads You will like them!
[Re: ]
#1873770
07/19/15 08:54 PM
07/19/15 08:54 PM
69dart
Johnstown
Well the weather was horrendous today. In the 90's with 76 dew point so I'm not sure how good of a back to back it was. The car ran exactly the same as it did the last time out. I think I'm going to add some timing and maybe fatten up a jet or too as it did seem a bit lean on the big end with. I set the timing at conservative 34. Most guys were a tenth or so slow and we ran the same so they 'might be better'. I'm just thrilled its put away in one piece and ready for the Mopar Nats
[Re: 69dart]
#1886633
08/06/15 11:04 PM
08/06/15 11:04 PM
Posts: 43,112 Bend,OR USA
Cab_Burge
any updates on your car with the newheads? Also, who did you buy yours from and where they complete and ready to bolt on? Thanks, Cab
[Re: 69dart]
#2063674
04/28/16 11:31 PM
04/28/16 11:31 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Update: The roadster has gone 5.98 @ 114 in the 1/8 and 9.63 @ 134 since replacing the heads.
I have to admin I'm pretty happy getting a 5.98 from a TRW piston 383 with a torker intake and 750 E85 carb. The car is just plain nasty with this combination. I couldnt be happier with these heads. Congrats man.............
#2105111
07/06/16 07:01 PM
07/06/16 07:01 PM
Posts: 13,354 Marion, South Carolina [><]
an8sec70cuda
Todd Marsh at Marsh Performance http://www.mopartsracing.com/
#2192308
11/08/16 06:40 PM
11/08/16 06:40 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I guess at this point the question is, is it a different head, or a CNC ported version of the std head?
Edit: I just checked the link. Looks like it's a CNC ported version of the std head.
[Re: GomangoCuda]
#2192471
11/08/16 10:51 PM
11/08/16 10:51 PM
BradH
How soon will we know how they compare to Trickflows? I'll take a w.a.g. and say you can use the published data for the MCH CNC-ported Stealth or Edelbrock Performer RPM for comparison.
#2193011
11/09/16 01:51 PM
11/09/16 01:51 PM
fast68plymouth
So. Burlington, Vt.
The MCH CNC rpm/stealth porting program is more like 251cc, so if these are 11cc less.... One might "assume" they would flow a little less.
#2197935
11/17/16 01:29 PM
11/17/16 01:29 PM
fast68plymouth
So. Burlington, Vt.
If they flowed that on my bench they would be better than the TF heads.
I for one don't think that would be the case........ But "ya never know".
#2414195
12/06/17 02:23 PM
12/06/17 02:23 PM
Posts: 2,094 central texas
krautrock
central texas
i just found these pics of the promaxx CNC ported heads. the price for these heads bare is pretty high, jegs has them complete for 1700 i think. I would wonder if all the CNC heads have the chamber done like on this listing. at 90cc in the chamber that might be a good option for someone trying to keep compression down some. there are small block heads listed too. promaxx BB promaxx SB
#2414211
12/06/17 02:44 PM
12/06/17 02:44 PM
fast68plymouth
So. Burlington, Vt.
The assembled heads are more money than the TF 240's...... And they're Chinese castings.
IMO, TF pretty much has that market covered as long as they keep the prices similar to what they are now.
