Re: ProMaxx Performance 440 heads
[Re: Stevenisme]
#1654654
03/30/15 09:10 PM
03/30/15 09:10 PM
Crabman and Dunnuck, I know each engine could be different, but in general, what is the pushrod clearance like with these heads and 3/8" pushrods and 1.5 rockers? Have you had to grind for clearance or not had to grind for clearance in most cases? Thanks!
I did not hear anything about the clearance. If there is before, there is not afterwards.
Steve I am doing one later this week on a 440 with 3/8ths pushrods and a .575 solid roller with Harland Sharp 1.5 ratio rocker arms I will let you know how it works out
[Re: Streetwize]
#1654656
03/31/15 10:06 PM
03/31/15 10:06 PM
We have been usingthem like popcorn--so far have done everything from swap them on a 440 with 509 hyd--wowzer--out of the box stamped rockers GREAT engine---- to some port work , 440 ,big hyd cam and an EASY 569HP first pull--full ported are showing better and better numbers as Larry zeros in on them--I have a set on a 511 right now that I just cleaned up on my back yard bench--street solid roller --will report as it moves along--not pulling every angle just tossing it together and see what happens-- So far with 1.5 PRW rockers and 3/8ths push rods I had them all clear on a street hyd roller unit--have Harlands on this 511 so we'll see soon as Smith gets the tubes here
[Re: young guns 90s]
#1799674
04/09/15 07:50 PM
04/09/15 07:50 PM
Posts: 1,412 Johnstown
69dart
Johnstown
Heads were delivered today. Pluses They look really nice... a very nice finished look Bowls and exhaust ports look perfect Very little cleanup left to do OOTB Minuses Need a little cleanup to match the intake ports Stamped locks so those will have to go Doesnt look like any of the holes are helicoiled so hopefully that wont be an issue I've ran 906's, Edelbrocks and 440 Source Stealth so far and would say the new ProMaxx Heads look very promising at an unbelievable price point. Once I get the intakes port matched and clearance the pushrod holes a bit for good measure I'll get to my engine builder to see what he thinks. I see 5.90's in my future
[Re: 69dart]
#1799802
04/09/15 10:22 PM
04/09/15 10:22 PM
crabman173
crabman173
3/8ths pushrods cleared with PRW stainless rockers--They will NOT clear with Harland Sharp 1.5's I worked and worked but was afraid of boring through an intake wall or worse so I quit and ordered Smith Bros 5/16ths pushrods for this 511 Smith says good for 700 open I got 460 range so am not worried about that part They clear ok at the bottom but up near the top it was trouble The Smith Brothers 5/16ths are my go to for this issue on street engine now--Geeez! I am getting too old for this I need a career change Steven in China Listen up!
#1799838
04/09/15 10:58 PM
04/09/15 10:58 PM
Posts: 1,800 North Dakota
Azzkikrcuda
North Dakota
I have been using the thick 5/16 from Smith Brothers on a few street engines. They work great, and I don't have to mess with clearancing the head.
The only Carbs I care about are under the hood!
#1799851
04/09/15 11:09 PM
04/09/15 11:09 PM
crabman173
crabman173
I actually sent for the .080 wall as they assured me they were stout enough they also had the .120 wall but -----he said they might make me sleep better but that at my 9 inch length the 080 was rated at near 700 open--I figured they knew and so... They do look like the future as far as I am concerned
#1873354
07/19/15 08:35 AM
07/19/15 08:35 AM
crabman173
crabman173
1.6 ratio is always a PIA on any Mopar head The Sidewinders are a bit fatter at the top of the intake port--I have had to do more on them than other heads You will like them!
[Re: ]
#1873770
07/19/15 08:54 PM
07/19/15 08:54 PM
69dart
Johnstown
Well the weather was horrendous today. In the 90's with 76 dew point so I'm not sure how good of a back to back it was. The car ran exactly the same as it did the last time out. I think I'm going to add some timing and maybe fatten up a jet or too as it did seem a bit lean on the big end with. I set the timing at conservative 34. Most guys were a tenth or so slow and we ran the same so they 'might be better'. I'm just thrilled its put away in one piece and ready for the Mopar Nats
[Re: 69dart]
#1886633
08/06/15 11:04 PM
08/06/15 11:04 PM
Posts: 43,007 Bend,OR USA
Cab_Burge
any updates on your car with the newheads? Also, who did you buy yours from and where they complete and ready to bolt on? Thanks, Cab
[Re: 69dart]
#2063674
04/28/16 11:31 PM
04/28/16 11:31 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Update: The roadster has gone 5.98 @ 114 in the 1/8 and 9.63 @ 134 since replacing the heads.
I have to admin I'm pretty happy getting a 5.98 from a TRW piston 383 with a torker intake and 750 E85 carb. The car is just plain nasty with this combination. I couldnt be happier with these heads. Congrats man.............
#2105111
07/06/16 07:01 PM
07/06/16 07:01 PM
Posts: 13,319 Marion, South Carolina [><]
an8sec70cuda
Todd Marsh at Marsh Performance http://www.mopartsracing.com/
