2 speed trans A body
#1645550
07/12/14 01:57 AM
07/12/14 01:57 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
will an ati trans with there sfi case fit in the stock trans tunnel with the motor in the stock location. using a mid and motor plates i will be using a tubular k member and coil over out front..some pics would be very helpful. i need to leave the fire wall and tunnel intact.for a class that i might run in the near future. but for now im looking at 9.60 index so a power slide seem like the way to go...
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
Re: 2 speed trans A body
[Re: J_BODY]
#1645552
07/12/14 11:22 AM
07/12/14 11:22 AM
WHITEDART
bean town ....Ca
i will go back to a profight 904 after.i am going try some of the index stuff.thanks for the info
[Re: WHITEDART]
#1645553
07/12/14 04:12 PM
07/12/14 04:12 PM
Posts: 1,499 San Antonio,TX
440W8 Duster
San Antonio,TX
I have a JW Ultra case with bell and roller tail shaft and a stock type dipstick and didn't have to modify the tunnel at all just had to bend the dip stick tube to clear the fire wall. I just modified the stock trans cross member mount to the glide. I will take some pictures of the tunnel when I get home tonite.
70 Duster W8 motor. 1.29 60ft 5.79 1/8 at 120 mph glide with 1.80 gear @3170 lbs.
