Re: Jetting& Altitude
[Re: pjc360]
#1644705
07/17/14 11:23 PM
07/17/14 11:23 PM
Posts: 5,443 Indiana
YO7_A66
Indiana
The engine may have liked the orange pump cam because of the .025/.028 IFR's. It helped cover the lean spot.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: pjc360]
#1644711
07/20/14 07:42 PM
07/20/14 07:42 PM
YO7_A66
Indiana
.005" times four IAB's. I would guess that the .070's are your leanest limit. I would suggest going down another .005" each to be safe. You will need to reset your metering screws again.
[Re: pjc360]
#1644713
07/20/14 10:10 PM
07/20/14 10:10 PM
YO7_A66
Indiana
Remember, one change at a time. I would test the .065's first and then the .063's if required. If you need to go richer after that, then open up the carb and change the IFR's. Good luck with the O2 purchase.
[Re: pjc360]
#1644721
07/21/14 05:06 PM
07/21/14 05:06 PM
YO7_A66
Indiana
So you had glowing headers on .033, .031, .028 & .025 IFR's!! (I edited this due to the next response)
EDIT: Question for other members: Could an intake leak on that side of the engine cause the headers to be red? Could an intake leak cause the popping sound out the exhaust too?
