Re: Sector support kit (steering) - anyone try it?
[Re: RylisPro]
#1643245
07/07/14 06:48 PM
07/07/14 06:48 PM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
I've welded one simple gusset on the steeringbox mountpad and clearly felt the difference (A-body). Would like to add the sectorsupport but I'm now doubting that it will improve much except lessen the wear on the inner bearing in the box itself.
[Re: MoparCar]
#2484932
04/19/18 02:26 AM
04/19/18 02:26 AM
Posts: 10,498 Chicago, Illinois
Devil
Chicago, Illinois
Anyone installed one with a QA1 tubular k-member? Thanks- I am literally working on this right now. It will need some work to be done, because the mounting area that is on the normal K-member isn't on the QA1. I'll let you know how it develops.
[Re: MoparCar]
#2485528
04/20/18 11:51 AM
04/20/18 11:51 AM
Posts: 5,386 Pikes Peak Country
TC@HP2
Pikes Peak Country
The bearing support always struck me as a fix for cars that were all put together, for owners that didn't want to do any disassembly and welding ,to shore of the box mount. I'm sure adding a support to a gusseted k also provides a very nominal improvement, but reducing box deflection is the biggest gain either mod achieves, and both of this are fairly small. Anyone installed one with a QA1 tubular k-member? Thanks- Don't know that it would work on a tubular replacement K since the bearing support is designed to mount on the lip of the stock K. I'm sure things could be modified or a tab welded on to allow it.
[Re: TC@HP2]
#2485751
04/20/18 08:00 PM
04/20/18 08:00 PM
Devil
Chicago, Illinois
The bearing support always struck me as a fix for cars that were all put together, for owners that didn't want to do any disassembly and welding ,to shore of the box mount. I'm sure adding a support to a gusseted k also provides a very nominal improvement, but reducing box deflection is the biggest gain either mod achieves, and both of this are fairly small. Anyone installed one with a QA1 tubular k-member? Thanks- Don't know that it would work on a tubular replacement K since the bearing support is designed to mount on the lip of the stock K. I'm sure things could be modified or a tab welded on to allow it. It's more of an issue of the pitman arm hanging out in the air per-say, being in single shear mounted on only one side. It can deflect around a bit outside of rotation of the arm because of the pressures being exerted on it. With this kit, it puts it in double shear, and allows for a fluid movement with no deflection. Which makes steering much nicer and less floaty.
[Re: TC@HP2]
#2485918
04/21/18 02:17 AM
04/21/18 02:17 AM
Devil
Chicago, Illinois
I don't disagree that double shear mounting is a better arrangement, but how much is the cast iron housing and hardened steel shaft of a steering box flexing compared to the thin stamped steel and spot welded structure of the F frame and box mount? Have you watched a steering box moving around while being cycled through the steering range? The flex of the box within the mounting system of the k frame is a much greater detriment to steering response than deflection of the steering box and pitman arm. You can reduce that flex via a double shear mounting on two planes by supporting the lower end of the box, or by reducing the flex inherent with the mount. Either way are very effective at improving steering response. One requires an afternoon of effort with a plasma cutter, grinder, and a welder, one requires an hour with a drill. Both achieve the same result. Oh I agree, the mounting on a stock k-member is poor. I've seen the flex in the stock mount before. I've also seen the shaft pivoting in the power steering box. I believe that with the shaft in double shear that it will prevent a lot of wear on the box as well.
