Page 6 of 6 1 2 3 4 5 6
Re: 340 not what I thought it would be...Any ideas? [Re: Telvis] #1642577
07/20/14 03:21 PM
07/20/14 03:21 PM
scratchnfotraction Offline
All I can say is Wow! I had no idea how much difference a good torque converter could make. Between the lower transmission gears, the fine tuning on the distributor and the torque converter my car is now officially a beast! It's almost scary now. I hammered it and it would not stop spinning! It spun all the way into second gear! I even punched it once when I was moving about 15 mph and it lit up the tires! I just came back from about a 45 minute ride. I now have about half the tire tread that I started with.
I can't think everyone enough for all of the advice. I need to send an extra shout out to RapidRobert for all of his help. You guys are the greatest.
I wish you guys could have seen the ear to ear smile on my face when I was roasting the tires!
I have my sights set on a set of 3:55 gears. I can't wait to see how that does.
Your face is going to be stuck in smile mode every time you drive it now. At the rate of 1/2 a tire every 45 mins your wallet will hurt but you will still be smiling while you watch the tire shop install new tires.
would be a good time to add a torque strap to the engine, lube up the u-joints, spoon up the rear brakes now that it will launch faster.
Re: 340 not what I thought it would be...Any ideas? [Re: scratchnfotraction] #1642578
07/20/14 04:06 PM
07/20/14 04:06 PM
KY
Telvis Offline OP
Telvis  Offline OP
KY
Yep, I think I will be investing in ties pretty frequently.
My driveshaft and U Joints are brand new and all lubed up... I installed drilled and slitted disc brakes on all four corners over the winter. As far as a torque strap I'm not sure about that. Might need some frame connectors...That looks like a good winter project. Right now I am going to enjoy it for a while.
That's King Weenie to you!
Re: 340 not what I thought it would be...Any ideas? [Re: Telvis] #1642579
07/21/14 02:24 PM
07/21/14 02:24 PM
dogdays Offline
dogdays  Offline
I'm one of the guys who said go to 3.91s. If you are spinning all the way into Second gear, you don't need more gear than what you already have.
Keep the 3.23s!
Drive the doggone thing.
R.
Re: 340 not what I thought it would be...Any ideas? [Re: dogdays] #1642580
07/22/14 11:51 AM
07/22/14 11:51 AM
Keep the 3.23s!
R.
I think the new TC did the trick with 3.23 , the old TC with a 3.91 would have been the same results.IMHO.
Re: 340 not what I thought it would be... UPDATE!!!! [Re: Telvis] #1642581
07/22/14 11:59 AM
07/22/14 11:59 AM
CENTRAL MINN
1965_PLYMOUTH Offline
CENTRAL MINN
Gee, Beave. I don't know if you could get a bigger tire under that car. far cry from a F78-14. if you wanna smoke tires, just put the original wheels and tires on.
Re: 340 not what I thought it would be...Any ideas? [Re: scratchnfotraction] #1642582
07/22/14 12:21 PM
07/22/14 12:21 PM
KY
Telvis Offline OP
Telvis  Offline OP
KY
Keep the 3.23s!
R.
I'm going to enjoy it for now. At least until I have to buy a new set of tires!
Re: 340 not what I thought it would be...Any ideas? [Re: dogdays] #1642583
07/22/14 12:43 PM
07/22/14 12:43 PM
North Austin
KnuckleDuster Offline
North Austin
Good thread! Glad to see it worked out well.
Curious about the pricing on that convertor?
Been thinking about swapping out my 2800 stall....
