Re: 340 not what I thought it would be...Any ideas?
[Re: Telvis]
#1642518
07/08/14 01:01 PM
07/08/14 01:01 PM
Posts: 5,443 Indiana
YO7_A66
Indiana
""I ordered a Turbo Action TC today. Should give me more stall.""
Which unit did you buy? Paul spec'd out a Tight 10" for me and it flashed to 3500rpms with 3:55's and 26" tires. That made a huge difference in my bottom end torque over the stock converter that I swapped out.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: Telvis]
#1642519
07/08/14 03:52 PM
07/08/14 03:52 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Like others asked, do a Compression check to see where the motor sits as is. 110?, 130?, 160? etc.
With the pistons above deck and that cam, should be around 150+ IMO The 3.23,s arent helping for sure. Does it run super in the power band?. Also, check the plugs, you could be Pig rich/ or lean.
[Re: Sport440]
#1642520
07/08/14 06:38 PM
07/08/14 06:38 PM
Posts: 464 KY
Telvis
KY
Paul took all of my specs and recommended the converter that ends in ST. I can't remember the model number. It's the 10 inch, 3500 stall unit.
I will check the compression as soon as I can. I work late so may be the weekend. Will check plugs when I do.
That's King Weenie to you!
[Re: Telvis]
#1642521
07/08/14 06:40 PM
07/08/14 06:40 PM
Posts: 464 KY
Telvis
KY
Timing maxes out around 2500 rpm
[Re: Telvis]
#1642522
07/08/14 06:41 PM
07/08/14 06:41 PM
YO7_A66
Indiana
""Paul took all of my specs and recommended the converter that ends in ST. I can't remember the model number. It's the 10 inch, 3500 stall unit.""
That is the "tight" 10" unit that I and a few other members had/have behind their SB's. Good choice!!
[Re: Sport440]
#1642524
07/12/14 08:40 PM
07/12/14 08:40 PM
Posts: 464 KY
Telvis
KY
Ok....I finally had a chance to check my compression and my plug condition...
All plugs looked really good. Actually better than I expected.
The compression was fairly consistent in the 180 psi range for all 8 cylinders. I checked each one twice. Anyone care to give me input on that number? Is it good or bad? I think it's probably decent but I don't know that much about the meaningfulness of a certain number.
I checked my carb float level and made a couple small tweaks. They were a tad on the high side. I also change the vacuum secondary spring to the next lighter spring just to see if it would make a difference. I didn't mess with the mixture because my plugs looked so good.
The car will spin tires from a dead stop for about 4 to 6 feet without power braking. I don't guess thats too bad for a 340 and 3:23 gears.
I received the new Turbo Action torque converter this morning. I don't think I will be able to install it this weekend. I may be able to get it done next weekend if my wife doesn't bury me in honey do items. I will let you all know how the TC works for me. I think I am also going to try to find a 3:55 gear set. I may wait unit The Nats and look for one there.
[Re: Sublime70]
#1642528
07/12/14 08:52 PM
07/12/14 08:52 PM
Posts: 464 KY
Telvis
KY
I have a Hughes 27-25 right now. It's a 2500 rpm stall.
[Re: ahy]
#1642530
07/12/14 09:31 PM
07/12/14 09:31 PM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
[Re: ahy]
#1642531
07/12/14 11:46 PM
07/12/14 11:46 PM
Posts: 464 KY
Telvis
KY
Do my aluminum heads give me a "cushion" on the gas I am able to use? I have never had the slightest knock. I do use premium but have accidentally used regular with still no valve chatter.
[Re: Telvis]
#1642532
07/12/14 11:59 PM
07/12/14 11:59 PM
RapidRobert
Do my aluminum heads give me a "cushion" on the gas I am able to use? I do use premium but have accidentally used regular with still no valve chatter.
(1) yes (2) if you have an aggressive curve & still no knock with regular I would use it. EDIT 180 is healthy, the timing does need to come in much faster (what springs do you have?) which will likely make you stay with premium. If the AF ratio is adequate you may very well need less cam and or more converter (not my area). Keep us posted
[Re: Twostick]
#1642534
07/13/14 12:56 AM
07/13/14 12:56 AM
Posts: 464 KY
Telvis
KY
I am sitting on about 22 to 24 initial and about 38 all in at the moment. I tweaked the timing a bit earlier today. With the vacuum gauge I am good at no more than 24. I have one purple and for the life of me I can't remember the other spring color in the distributor. It comes in pretty quick and all in around 2500 rpm.
I just received a new 3500 rpm stall torque converter. I plan to get it in next week. Hopefully it will improve things a bit.
The heads are Edelbrock 60179 for a 340. The chamber is 65cc which in hind sight I understand I probably should have went for a different head. I went with these because they were supposedly made specifically for the 340. If all of my "tweaks" fail I might have them milled down a bit over the winter. I will cross that bridge when I get there.
