Re: Mcleod twin disc clutch trouble
[Re: General 68]
#1637685
07/03/14 08:45 AM
07/03/14 08:45 AM
Posts: 3,325 Truckville, the capital of NY
85_Ram_4speed
No experience with a twin disk, but I set up my old Dartsport with a stop as was suggested previously and no overcenter spring. If you adjust the clutch right, there will actually be very little movement in clutch pedal travel to get the disk to release. Mopars have WAY to much travel in stock form. It took me having someone in the car pressing the pedal while I got underneath to see what was actually happening. I think I set my air gaps to be about .090 on the several different clutches I tried, anything much tighter and it was hard to shift at high speed---again, this is what I determined worked for me.
I'd be willing to bet if someone pressed the clutch for you while you under neath, measure your air gap and have the assistant note where the pedal started and stop to achieve that, you'd see it doesnt take much travel at all. My pedal actually was not any higher off the floor than my brake pedal--in fact it was lower---stock it was alot higher than the brake pedal. It doesn't matter which side of the pedal you limit, or both, you just need to limit it for a specified distance. And make sure the linkage geometry is right too.
Outcast Dodge guy.
[Re: 85_Ram_4speed]
#1637687
07/03/14 11:17 AM
07/03/14 11:17 AM
Posts: 2,041 MD
RTSE4ME
MD
I would do this.
[Re: RTSE4ME]
#1637688
07/03/14 08:20 PM
07/03/14 08:20 PM
Posts: 1,169 clarks summit pa
73cuda340
clarks summit pa
I had a helper working the pedal while I was underneath. I just got it to the point where it will disengage. Im just going to live with the lower pedal. I got it to be about halfway now.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
