Re: Which distributor is everyone's preference
[Re: Triple Threat]
#1634128
06/17/14 11:07 AM
06/17/14 11:07 AM
Posts: 13,351 Marion, South Carolina [><]
an8sec70cuda
I have an 11 year old MSD pro billet distributor on my hemi. The inside is crusty looking, but never had a problem w/ it. Recently switched to a crank trigger...runs the same. The rust evidently doesn't hurt anything. For a crank trigger deal, you can run pretty much any distributor and be fine. I have MSD 6al boxes on all our cars. I don't care for the MP boxes and the ridiculous claims made about the Rev-n-ator were enough to convince me never to buy one.
[Re: 440Jim]
#1634132
06/17/14 10:56 PM
06/17/14 10:56 PM
Posts: 4,647 aotearoa
rebel
aotearoa
Has anybody used one of the inexpensive ones on the market now? At $55 for a new distributor with good features, somebody must have tried them. Ebay link - 440 Mopar Distributor Quote:
• A billet of 6061 - T6 aluminum CNC is machined into a perfect housing for incredible strength, precision and looks.
• Sealed ball bearings, sintered bushing, 1/2 inch hardened steel shaft • Extremely accurate magnetic pickup which never requires adjustment. • Designed with a small base and cap to suit all makes and models. • This is mainly used in high performance vehicles which have space limitations around the engine.
yep, if you look back a page you'll even see my pic of my motor with one fitted. as I said in my post, it's a great dizzy but it's internal magnetic trigger is rubbish, but if you're using a crank trigger, these dizzys work well.
[Re: rebel]
#1634134
06/19/14 03:57 PM
06/19/14 03:57 PM
Posts: 16,923 NC
440Jim
NC
When I first read your post I missed the connection to the ProComp distributor in the middle, I looked it over too quickly. I imagine most of these off brand ones are made in the same factory. Thanks for the feedback. I used a stock distributor with the weights welded with my crank trigger for many years. But now I am waiting on a KB alumuminum block and their "low deck" still uses a RB distributor so I need to buy something. For $55 I could disable the mechanical advance for use with my crank trigger and MSD ignition box. New housing (CNC), new ball bearings, etc. and it clears the valve covers with Indy heads
[Re: Cab_Burge]
#1634135
06/19/14 04:06 PM
06/19/14 04:06 PM
Posts: 4,663 Wichita
GY3
Wichita
I like and use the stock Mopar magnetic pickup distributors with vacume and mecahical advance. I weld the slots up to limit the mechanical advance to 18 to 20 crankshaft degrees , 9 to 10 distributor degrees, so I can set the initial timing at or cloes to 14 to 16 BTDC I buy the Mr Gasket Chevy distributor spring advance kit and use both of those skinny little short rascals I think the Mr G part # is 25B, if not let me know and I'll go out in the shop tomorrow and verify the correct part number for you
The Mr.Gasket spring # for Chrysler electronic dist. Is #925B
[Re: megajoltman]
#1634137
06/19/14 06:18 PM
06/19/14 06:18 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I have this dist sitting here.. I think its a MP part and its pretty nice.. easy to set the advance on.. just loosen a screw and slide the advance and tighten the screw.. this one is new but I forgot where I got it from
[Re: cudaman1969]
#1634140
06/20/14 02:12 AM
06/20/14 02:12 AM
Posts: 43,096 Bend,OR USA
Cab_Burge
Factory stock elec dist. (most are free) with one tiny spring, all in when started, MSD 6 or 7 and right coil. Then worry about other things more important. All i used since 1974, still got the 7 box with the 5 pin hook up. So simple a cave man can use one.
My MSD 404 C box quit at the MATS race three years ago, it was Sunday morning, I was the first car in the left lane for the first round of Pro and the box to a hike I had a spare MSD7C in the trailer that I could have swapped and bought back in but I figure it wasn't meant to be that day so I put in the trailer and towed it home 850 miles without a fisrt round win Nothing last forever, even the best parts die and wear out
[Re: Cab_Burge]
#1634141
06/20/14 12:26 PM
06/20/14 12:26 PM
Posts: 2,763 Walton's Mountain, Pa
Steve1118
Add me to the list still using the old MP tach drive dizzy. Still using the old mechanical SW tach, too, left over from the old factory race days.....
"Old age and treachery trumps youth and enthusiasm, every time!" East Central Director / Chrysler Power Magazine www.reasbeckracing.webs.com
