Page 3 of 3 1 2 3
Re: The famous Neon rough idle question... [Re: Grizzly] #1632689
06/17/14 10:56 AM
06/17/14 10:56 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
...........I'll have to check my coil pack too, and I still have to check the resistance on my injectors.
I had 12.4 to 12.7 Ohm all the way across on mine.
Injector Testing
Also, in that troubleshooting series I used their method for testing the coil:
Coil Test
Had a nice, fat spark.
I pulled all the plugs last night and tightened the gap to .30: run it again for awhile and see what happens.
Good luck.
I'm still thinking about drilling the hole in the throttle plate....
Something to think about; The computer is always trying to hit the programmed idle speed and uses both air flow and timing to get there. If you drill the plate allowing more air in and the computer can't control the idle with the IAC, it will do it with timing. So it could pull too much timing out at idle.
Less timing at idle may not be a good thing.
Master, again and still
Re: The famous Neon rough idle question... [Re: DaveRS23] #1632690
06/17/14 11:31 AM
06/17/14 11:31 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
My question is, did you reset the computer after you fixed the vacuum leak?
Don't be the exception.
Re: The famous Neon rough idle question... [Re: Supercuda] #1632691
06/17/14 02:02 PM
06/17/14 02:02 PM
Stow ,Ohio
demon440 Offline
demon440  Offline
Stow ,Ohio
I have an 04 Neon with 95,000. miles
I am the original owner. This car had a rough idle since day 1. Dealer told me it's normal.
Recently it has a bad stumble, almost like it cuts out. In the past I have put 2 MSD coils on it and changed plugs and wires. Recently replaced
the solenoid on the fire wall for emissions but that didn't help.
Re: The famous Neon rough idle question... [Re: demon440] #1632692
06/21/14 05:22 AM
06/21/14 05:22 AM
North Central Florida
E
eightlitermopar Offline OP
E
Quick update. I have done nothing but drive the car
Seriously though, I didn't know if the car was relearning or not after being in the shop. I put some Lucas injector cleaner in and have been driving it.
Idle still hovers about 600-800 RPM, starts right up and drives fine.
I guess I can't complain though. I have seen some 4 cylinder cars shake so bad at idle you would think it had an uneven washing machine running under the hood.
I do want to do a compression test though just for kicks. I will post the results as soon as I get them.
eightlitermopar
Mopar or no car
Re: The famous Neon rough idle question... [Re: That AMC Guy] #1632693
06/22/14 12:19 AM
06/22/14 12:19 AM
Harrisburg Pa. 17112
moparmikethree Offline
Have the timing belt rechecked. It is off a tooth on the can sprockets
Re: The famous Neon rough idle question... [Re: demon440] #1632694
06/22/14 12:26 AM
06/22/14 12:26 AM
SE PA
Yellow Fever Offline
SE PA
Do the timing belt, water pump and tensioner if you haven't yet! It will bend valves if it breaks!!
Re: The famous Neon rough idle question... [Re: moparmikethree] #1632695
06/22/14 01:45 PM
06/22/14 01:45 PM
E
E
I thought of this, but I understand that if it is off 1 tooth it will throw a code
Mopar or no car
Re: The famous Neon rough idle question... [Re: eightlitermopar] #1632696
06/22/14 02:35 PM
06/22/14 02:35 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
You might try directing some propane from an unlit torch into the intake to the air filter after the engine is fully warmed up.
(when started cold the air fuel ratio is very rich anyway)
If one or more of your fuel injector tips have deposit build ups interfering with the short solenoid plunger up down at idle, the extra propane should smooth out the idle.
If the IAC is working correctly it should adjust while this is happening and RPM should keep returning to spec as the propane is quickly added or taken away.
While you have the propane torch out check for air leaking past gaskets or o- rings.r
Carbon deposits on the backsides of intake valves can also cause a rough idle.
If you are going to keep driving it
add a bottle of Chevron Techron Plus to your next tank,
a bottle of Gumout Regane to the 2nd tank,
then a bottle of Redline SI-1 to the third tank.
This is about the cheapest thing you can do
considering the cost of man-hrs
and based on the idea that:
"what one cleaner cannot dissolve, another one might".
Re: The famous Neon rough idle question... [Re: 360view] #1632697
06/22/14 11:48 PM
06/22/14 11:48 PM
E
E
The car runs great above 800 RPM. I will try some of the additives to see if that helps.
I'll let you know if anything changes, but I am accepting the fact that I just might have a slightly rough idle for the rest of the days I own this car. With the cost of cars going up and up, I plan on driving this car into the ground.
Mopar or no car
Re: The famous Neon rough idle question... [Re: eightlitermopar] #1632698
07/08/14 03:24 PM
07/08/14 03:24 PM
E
E
So, here is my latest update.
The car was running very rough at idle and seems to be getting worse. When the car is in “drive” at idle, it started developing a loud “chirping” sound that gradually got louder.
I took it back to the shop that did the timing belt, water pump, and replaced 2 motor mounts.
Long story short: The new motor mount/strut on the passenger side of the motor was adjusted properly (front to back), but the adjustment (side to side) was a little close to the motor. It was just enough that the idle would cause it to make contact and really vibrate the car.
After a readjustment, it idles A LOT smoother. However, there still is a bit of a shake at idle, but nothing close to what it was. They claim that if I replaced all of the mounts, it would smooth out like a new neon.
Based on what I experienced just with just one properly adjusted mount/strut, I totally believe it.
Mopar or no car
Page 3 of 3 1 2 3
