Re: 340 Compression test
[Re: mopowers]
#1630311
06/07/14 11:28 PM
06/07/14 11:28 PM
Challenger 1
Cincinnati, Ohio
I just did a cold compression test on my 340 and got the following numbers: Should I be concerned about #8 being so low?
Also, these numbers seem high to me. Will this thing be able to run (and live) on 91?
Intake is off and cam is MP 280/.474 purple shaft.
1: 205 2: 197 3: 200 4: 182 5: 185 6: 182 7: 190 8: 170
No I would not be concerned about it, just as long as it stays that way. Least you know about it know and can keep an eye on that plug for any changes.
I built my 340 a few years ago and CC the head and measured the piston .029" above the deck and came up with 10.4-1 static compression and my motor has consistently cranked 165-170 on all cylinders. It runs fine on 91 octane straight gas when I'm at home with the car and I have run it on plenty of ethanol 92-4.
I like your higher readings, it should run good. How much octane is it going to need? I have no idea, but I would start hi.
Just got back from cruising my 340 challenger with the wife and dog. We go house hunting and rumble down these residential streets and everyone looks.
I am running that same cam, I like it.
[Re: mopowers]
#1630312
06/08/14 12:23 AM
06/08/14 12:23 AM
RapidRobert
I'd be doubtfull on running 91 especially as you dont want to have to compromise the curve. Yes #8 is substantially lower (17%) than the highest one. As said I'd start with a partial % tank of race gas & work downward. Keep in mind you need a fast curve to take advantage of your build & for that plus your posted SCR you're gonna need good fuel. To adj the curve the way I do it (staying just under the pinging point) you need the fuel type/% of race gas to be finalized
[Re: autoxcuda]
#1630315
06/09/14 11:45 AM
06/09/14 11:45 AM
Posts: 3,007 Sac, CA
mopowers
Sac, CA
Thanks for the input guys. The motor is fresh and was built before I bought the car. It was running on 91 before I did the compression test, albeit not that well. I'm in the middle of an intake swap and figured I'd degree the cam to get a better idea of where everything is. Hopefully I can get everything back on the road with what I've got and running on CA pump gas.
Thanks again.
What's "not well"? Was is pinging, hesitating, not smooth idle, bogging....?
Did the previous owner say it had that MP cam in it. Receipts on motor work?
Why the intake change?
big question is how much actuall measured compression ratio you have.
It wasn't pinging before, I just never could get the tune right. I couldn't get it to idle very well in gear. It dropped 300 rpms when put in gear. I had the timing set at 22 initial and 35 total.
Previous owner told me he had installed the MP cam. I verified the cam with a dial indicator and degree wheel.
I'm swapping intakes because I have an RPM air gap and the it previously had a torker 340 intake on it.
I have no idea what the measured compression ratio is. The previous owner told me it's a stock rebuild, but I have nothing to go on and don't really want to pop the heads off to measure.
[Re: mopowers]
#1630316
06/09/14 12:30 PM
06/09/14 12:30 PM
RapidRobert
Actually your cranking compression tells the story. Challenger1 has a measured 10.4/165-170 psi and you're way higher than that on the psi plus I'm assuming no quench so I would say no way on pump gas. As you know pinging is extremely damaging & must be avoided at all costs.
[Re: RapidRobert]
#1630317
06/09/14 01:01 PM
06/09/14 01:01 PM
mopowers
Sac, CA
I get what you're saying, but why on earth was this engine able to run on 91 without pinging then? There were no signs of detonation that I could see. The plugs look fine, albeit a bit on the rich side.
[Re: mopowers]
#1630318
06/09/14 03:13 PM
06/09/14 03:13 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Nothing like that is a given. There are too many variables that will can effect the end result.
[Re: MoparforLife]
#1630319
06/09/14 03:25 PM
06/09/14 03:25 PM
Challenger 1
Cincinnati, Ohio
Cam timing can affect cranking psi with the same compression.
[Re: mopowers]
#1630321
06/09/14 04:06 PM
06/09/14 04:06 PM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
Some basics that should be considered: 1. The cylinder pressures generally decline from front to back. If the engine was a rebuild under the previous owner a less careful machine shop may have milled the block deck out of level with the centerline of the crank. Alternately, the machine shop may have milled the cylinder head surfaces without first checking to see if the finished cc's of the combustion chambers would be as equal as practical. 2. Is the gauge on the compression tester accurate? If it were mine i would rig up some adapters and check it against "known good" gauges on a stable pressure source like a portable air tank. 3. Borescopes have become remarkable good and relatively inexpensive. The Harbor Freight 9mm diameter head size one made by Autel can slip through a 14mm sparkplug hole and show you whether abnormally high compression readings are due to carbon deposits. http://www.amazon.com/Autel-AULMV20155-M...gital+borescope4. The 170 psi reading low cylinder should routinely have a second test after adding two tablespoon sized squirts of 50 weight engine oil to the high side of piston gap in the cylinder and turning over the engine by hand a time or two. If pressure increases with this "wet test" more than 20 psi there is something wrong with the rings or maybe bore finish or size in that cylinder.
[Re: 360view]
#1630322
06/09/14 04:46 PM
06/09/14 04:46 PM
mopowers
Sac, CA
To answer one of your questions, The compression gauge is an old Proto. I tested it with an air blow gun and my compressor. They were equal.
I haven't done a wet test on #8, but that sounds like a good idea.
[Re: maxwedge1]
#1630325
06/09/14 09:33 PM
06/09/14 09:33 PM
Challenger 1
Cincinnati, Ohio
I have similar readings 180-190 psi with x heads, 10.4:1. a bit larger cam, 108 lsa and need minimum 100 octane to keep it from rattling.
Good point, my heads are Edlebrock aluminum.
[Re: maxwedge1]
#1630326
06/09/14 09:37 PM
06/09/14 09:37 PM
Posts: 1,212 Canton, Ohio
Crazy68Dart
Canton, Ohio
How exactly did you perform the compression test?
383, Hemi 4-Speed, AlterKtion, D60
[Re: Crazy68Dart]
#1630327
06/09/14 10:03 PM
06/09/14 10:03 PM
RapidRobert
Oh OK I see what you are saying. it did not ping but it was just not "right". A person could dribble some water in the carb at a fast idle to loosen up any carbon then take it out for a good blast to expell the carbon which "may" give a false high reading (clean the plugs afterward) and I loosen the plugs on any compression test several turns then tighten em back up then start it & gun the throttle several times to expell potential loose carbon particles coming off of the threads which could lodge under a valve and give a false low reading then pull the plugs & continue on with the compression test. Kinda picky but that's me. Actually I would forget about the SCR/cranking psi for now and button it up with the new intake then concentrate on fixing (in this thread) what ain't "right" on the tune then move on to the fuel needed and the ign curve but your initial sounds healthy and the total ain't outrageous & not sure when it comes in at (springs) but we gotta address/fix the "problem". But you do have iron heads with no quench and those cranking psi numbers are very high & I hear that gas out on the left coast is the worst. But If it ain't pinging then it ain't pinging & that's the bottom line. Stay on it & keep us posted
[Re: 360view]
#1630328
06/10/14 10:00 AM
06/10/14 10:00 AM
Posts: 8,162 USA
360view
USA
Now that NASCAR has limited static compression ratio, the tech inspectors are said to be using a "whistler" device to make quick no tear down checks of static compression ratio. http://www.katechengines.com/motor-sports/services/whistler/has anyone on moparts used one of these?
[Re: 360view]
#1630330
06/10/14 11:55 AM
06/10/14 11:55 AM
mopowers
Sac, CA
Explanation by Jon Jeffords of Hartford WI:
the way it was explained to me, the Katech whistler is basically an acoustic measuring device that functions much like when you blow air over the top of a beer bottle.
Oversimplified, as the whistler blows air over the the spark plug hole while the piston is at TDC, it measures the resulting natural frequency of the air volume resonating in the combustion chamber. Knowing the air temperature, the Whistler calculates combustion chamber volume at TDC. Knowing the engine's displacement (bore & stroke) and number of cylinders, the Whistler can then calculate compression ratio.
Pardon the ignorance, but what would number of cylinders have to do with calculating compression ratio?
[Re: MoparforLife]
#1630331
06/10/14 11:56 AM
06/10/14 11:56 AM
mopowers
Sac, CA
Also if the engine is fresh, give it some time to fully seat the rings. They say that they seat relatively quick now days but there are a lot of variables here too. Including type of rings used. Give it a little time. If it runs strong don't worry about it.
Thanks for the input. Ultimately, it's gonna go back together and run. I'll see how it runs before I make any changes.
[Re: Crazy68Dart]
#1630332
06/10/14 11:59 AM
06/10/14 11:59 AM
mopowers
Sac, CA
The intake is already off. I first pulled the plugs. The battery was dying, so I actually had to jump it with the battery in my running truck so it had enough juice to do the test. I'm wondering if jumping it off a battery from a running truck may have given false high readings???
I spun each cylinder over for 5 pumps until the gauge quit going up, then took my reading.
[Re: RapidRobert]
#1630333
06/10/14 12:03 PM
06/10/14 12:03 PM
mopowers
Sac, CA
Thanks Rob. As always, I appreciate your help. I'll definitely keep you posted.
[Re: mopowers]
#1630334
06/10/14 12:34 PM
06/10/14 12:34 PM
Posts: 8,162 USA
360view
USA
Were the higher reading cylinders done first, perhaps with fresher batteries and higher voltage to the starter?
[Re: 360view]
#1630337
06/10/14 12:57 PM
06/10/14 12:57 PM
RapidRobert
# of cyls ain't needed for CR only for CID such as when you do the formula: bore x bore x stroke x .7854 (1/4 of Pi & dont ask me why) x # of cyls.
