reading these plugs
#1628656
06/04/14 05:21 PM
06/04/14 05:21 PM
Posts: 7,506 Az
Crizila
Az
NGK R5671A-9. I can get about 5 runs on a new set before the motor starts to miss above 4500. 408 blown application with water injection. If I clean them they are good again. Thinking about going to -8's or 7's and or running a little less water. Didn't have this problem when I was running cast iron heads. Seemed to crop up when I switched to aluminum heads? Thoughts??
Fastest 300
Re: reading these plugs
[Re: Crizila]
#1628659
06/04/14 05:48 PM
06/04/14 05:48 PM
Posts: 52,972 Romeo MI
MR_P_BODY
In the first pic they are so rich you cant read them.. lean it down.. the other pics are flashed out so I cant see them clearly EDIT isnt the 9 a cold plug and the 7 is hotter.. I can never remember which way is hotter
[Re: Quicktree]
#1628665
06/04/14 09:41 PM
06/04/14 09:41 PM
MR_P_BODY
you really can't tell crap if they have 5 runs on them
Those are FAT... period... but a hotter plug might do a lot for it... no one needs to change plugs that often... unless its a TF engine
[Re: MR_P_BODY]
#1628666
06/04/14 09:42 PM
06/04/14 09:42 PM
Quicktree
they could fat from the return road
[Re: Quicktree]
#1628667
06/04/14 09:58 PM
06/04/14 09:58 PM
MR_P_BODY
Come on Tony... he gets 5 passes and they are shot if its on the return road its DUMPING fuel.... but it can be a weak ignition also... either way those plugs are fowled
[Re: MR_P_BODY]
#1628668
06/04/14 10:55 PM
06/04/14 10:55 PM
Posts: 7,506 Az
Crizila
Az
Ya, agree with most of what's been said here. First, been through the ignition system in it's entirety and it is solid. What I know for sure is I get about 5 runs on it and the performance drops off ( engine miss ). Runs good when it's hittin on all 8 with speeds in the 129 MPH range, so the A/F can't be too far off at WOT. Yes, I gotta idle to staging and back to my pit area after my run. No boost, no miss. I can clean a set of plugs and make them work good again. I don't run an inner cooler. I do run a alcohol / water injection system. Run a mix - about 35% alcohol - probably do screwy things to a W/B 02 reading? Think I will try to drop some jet sizes and maybe put in a smaller water injection jet to see if that will help. My system is adjustable. I have it set for full spray pressure at 15 lbs of boost and over. Could try slowing it down? Also going to try a 1 step hotter plug.
Fastest 300
[Re: Crizila]
#1628670
06/04/14 11:25 PM
06/04/14 11:25 PM
MR_P_BODY
Dont do a bunch of things together... do the plugs and less water.. also whats the plug gap
[Re: Crizila]
#1628672
06/05/14 01:29 AM
06/05/14 01:29 AM
Posts: 43,007 Bend,OR USA
Cab_Burge
Try leaning down the primary jets two sizes and richen up the secondarys two sizes or the primary power valve enrichment channel the same amount of volume that the two jets sizes smaller are, if your using a power valve in the front(if not jet the back up two) That should help keep the plugs cleaner while putting around in the pits and still safe at WOT
[Re: Monte_Smith]
#1628674
06/05/14 06:44 AM
06/05/14 06:44 AM
Quicktree
If you are trying to read the plugs for power and proper mixture at WOT, you are just wasting your time the way you are doing it. The ONLY way plug reading works, is to make a power pull, kill the motor at the stripe and then read the plugs. Once you let it idle or drive it around, the plug reading is useless.
Monte
thankyou
[Re: Crizila]
#1628675
06/05/14 08:03 AM
06/05/14 08:03 AM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
Ya, the nice thing about doing the testing from home - I can do one change at a time and then go test. Made jet changes today and will test tomorrow. Send some fresh plug pics. Then do a test with less water, then with hotter plugs. My brother is sending me the alcohol correction factor program I will have to use if / when I install my wide band. .030" on the plug gap.
Don't you live up around the 5000' mark there in Payson.??
I'm thinking that won't help you one bit testing up there and racing down here..
And.. What Monte says..
Chris..
