Page 2 of 8 1 2 3 4 5 6 7 8
Re: Father/Son - BB D100 Project [Re: 340SHORTY] #1624575
05/26/14 07:06 PM
05/26/14 07:06 PM
Washington State
70Duster440 Offline OP
Washington State
I can see using one on an off-road 4x4 but how much difference will one really make on a street truck? Curious.
Re: Father/Son - BB D100 Project [Re: 70Duster440] #1624576
05/26/14 09:00 PM
05/26/14 09:00 PM
Truckville, the capital of NY
85_Ram_4speed Offline
The past couple a friend of mine and I got from the u-pull-it, came off of 2wd trucks. So the factory was obviously concerned enough to put them on there also. Inspect them where the strut meets the frame plate. We have seen the strut start to crack just past where they are welded. Some guesseting would be a good idea before install.
Outcast Dodge guy.
Re: Father/Son - BB D100 Project [Re: 85_Ram_4speed] #1624577
05/26/14 09:23 PM
05/26/14 09:23 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I put 1 on my old 81 Shorty. You could feel the difference in the steering wheel when going around corners.
I am truckless..
Re: Father/Son - BB D100 Project [Re: 70Duster440] #1624578
05/26/14 09:28 PM
05/26/14 09:28 PM
scratchnfotraction Offline
have someone turn the wheels lock to lock at idle,not moving while you watch the how much the box/frame flex under load.
a front sway bar and the brace really firmed up both of my trucks handling in turns and a big improvement for daily driving street duty.
Re: Father/Son - BB D100 Project [Re: scratchnfotraction] #1624579
05/26/14 09:49 PM
05/26/14 09:49 PM
Washington State
Washington State
Interesting. All good valuable feedback - thanks!
340shorty, still interested to hear what your friend wants but I'm going to check my local yard too. There are like, 2 trucks there.
Re: Father/Son - BB D100 Project [Re: 70Duster440] #1624580
05/26/14 11:30 PM
05/26/14 11:30 PM
East Texas
Mopar2DBone Offline
Mopar2DBone  Offline
East Texas
Just curious. Will a big block brake booster not work???
Re: Father/Son - BB D100 Project [Re: 70Duster440] #1624581
05/27/14 01:19 AM
05/27/14 01:19 AM
Marysville, WA
77ProStreet Offline
77ProStreet  Offline
Marysville, WA
Going to give Summit Racing's repackaged "whatever" paint a shot on this one (after all my kid will be driving it).
That's exactly the paint I'm using. Actually nice to shoot. Nice finish.
Re: Father/Son - BB D100 Project [Re: Mopar2DBone] #1624582
05/27/14 12:20 PM
05/27/14 12:20 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
still hits. I ran those covers on a low block and I had to unbolt the booster to get the cover off.
Re: Father/Son - BB D100 Project [Re: 70Duster440] #1624583
05/27/14 05:59 PM
05/27/14 05:59 PM
Washington State
Washington State
Only two Dodge trucks at my local yard. Neither had the brace.
Re: Father/Son - BB D100 Project [Re: 70Duster440] #1624584
05/27/14 07:28 PM
05/27/14 07:28 PM
anything else good on those trucks??
the small booster is what it would have with a B or RB enegine with stock late mid 70s smogger VC (not the HP tall penthouse VC)
still tight on R&R of VC.
on the mid 80s trucks you can go to the 86 3/4 ton vac booster which is a small one that has the alum 2 bolt MC.
it has been 'said' that you can hammer on the bigger pancake booster to get it to fit a BB in there... but that always looks like a chebby goober with a BFH has worked on dodge.
Re: Father/Son - BB D100 Project [Re: scratchnfotraction] #1624585
05/27/14 10:20 PM
05/27/14 10:20 PM
Washington State
Washington State
There was an '84 Ram with black booster and 2 bolt MC. My understanding is, even with the smaller booster, with (non-factory) tall valve covers you may have to relocate everything up to an inch further away from the engine???
http://www.bouchillonperformance.com/power_brake_boosters
Re: Father/Son - BB D100 Project [Re: 70Duster440] #1624586
05/27/14 11:03 PM
05/27/14 11:03 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
i've had 2 trucks, that had frame cracks develop at the steering box. after grinding out the crack, and drilling holes at the ends of the cracks, i had them welded up. i then ground down the welds, and used the braces. these were 2wd street trucks. the factory added the brace, after it became clear the frames couldn't handle the stress of the gearbox.
Re: Father/Son - BB D100 Project [Re: Mopar2DBone] #1624587
05/28/14 12:53 PM
05/28/14 12:53 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Bigblock booster is the small diameter. Same that 3/4 tons run and some halftons came with them
Re: Father/Son - BB D100 Project [Re: 70Duster440] #1624588
05/28/14 12:57 PM
05/28/14 12:57 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Black booster? For a 440 you just need to swap in a 3/4 ton booster of the same era truck. All 3/4 tons use the small diameter booster which in the 70s was the same used for 440 trucks. the 383/400 B-Blocks can use the big diameter but tall valve covers may be an issue
Re: Father/Son - BB D100 Project [Re: 76dodgeboy] #1624589
05/29/14 03:26 AM
05/29/14 03:26 AM
Marysville, WA
77ProStreet Offline
77ProStreet  Offline
Marysville, WA
I've been giving some thought to putting on a hydroboost system instead of a booster. First off its a lot smaller (No valve cover problems) and the brakes are way more responsive, especially if you put discs in the back or upgrade to larger discs all the way around. I had this on my 67 Coronet and it was a night and day difference on stopping performance!
[image][/image]
Progress: Father/Son - BB D100 Project [Re: 70Duster440] #1624590
06/27/14 11:31 PM
06/27/14 11:31 PM
Washington State
Washington State
Making some progress. Firewall and core support have been painted Viper Yellow (talk about vibrant), engine and trans in. Prepping the dash frame for paint and repairing the cab floor now.
Re: Progress: Father/Son - BB D100 Project [Re: 70Duster440] #1624591
06/28/14 08:52 AM
06/28/14 08:52 AM
Crockett ,TX
9
98RAM1500 Offline
98RAM1500  Offline
Crockett ,TX
looking good
Re: Progress: Father/Son - BB D100 Project [Re: 70Duster440] #1624592
06/28/14 01:55 PM
06/28/14 01:55 PM
Marysville, WA
77ProStreet Offline
77ProStreet  Offline
Marysville, WA
Dude you have been busy! That's looking great! What are you doing for wheels? I'm selling my cop car wheels and tires.
Re: Progress: Father/Son - BB D100 Project [Re: 77ProStreet] #1624593
06/28/14 05:13 PM
06/28/14 05:13 PM
that thing is nice work
Re: Progress: Father/Son - BB D100 Project [Re: 77ProStreet] #1624594
06/29/14 04:49 AM
06/29/14 04:49 AM
Washington State
Washington State
Thanks - I've got a set of 16x8's like the ones on my Duster but we were thinking of running black steelies on the rear with some Mickey T's or something - but tell me more about what you've got.
