Page 1 of 8 1 2 3 4 5 6 7 8
Father/Son - BB D100 Project #1624555
05/24/14 11:30 PM
05/24/14 11:30 PM
Washington State
70Duster440 Offline OP
Washington State
My 17 year old son and I are swapping a 440 into the ol' '75 D100 ("Banana Truck"). This project is for him.
We finished the steering/suspension rebuild with van LCA's...
Going to drop the motor and tranny in after painting the firewall Viper yellow...
I know the tall valve covers won't clear the power brake booster so in the interest of keeping things simple (and cheaper) going to swap to manual brakes. I already have a truck manual MC on the shelf. I'm guessing the factory used a studded reinforcing/mounting plate of some kind? Can anyone shed additional light on this?
Re: Father/Son - BB D100 Project [Re: 70Duster440] #1624556
05/25/14 02:28 AM
05/25/14 02:28 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
I don't recall any re-enforcement place but you can always customers make a plate just bigger than the booster pattern. weld stud or nuts to it or make it thice enough to tap the holes than use a nut on the backside?
Re: Father/Son - BB D100 Project [Re: 76dodgeboy] #1624557
05/25/14 02:35 AM
05/25/14 02:35 AM
Grand Forks, ND
Hemi_Ram Offline
Hemi_Ram  Offline
Grand Forks, ND
Check my thread out as I reinforced the manual MC from front to back.
https://board.moparts.org/ubbthreads/show...part=4&vc=1
Re: Father/Son - BB D100 Project [Re: 76dodgeboy] #1624558
05/25/14 03:27 AM
05/25/14 03:27 AM
Washington State
Washington State
Thanks for the feedback 76dodgeboy and Hemi-Ram! Looks like the simplest thing will be to fab a mounting plate. But, jeez, I hope we don't end up doing a heater delete too.
Re: Father/Son - BB D100 Project [Re: 70Duster440] #1624559
05/25/14 06:48 AM
05/25/14 06:48 AM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
while the front end is blown apart, now would be the best time to add a steering box brace.
Re: Father/Son - BB D100 Project [Re: Golden-Arm] #1624560
05/25/14 12:52 PM
05/25/14 12:52 PM
Grand Forks, ND
Hemi_Ram Offline
Hemi_Ram  Offline
Grand Forks, ND
Here is a pix of the brace
Re: Father/Son - BB D100 Project [Re: Hemi_Ram] #1624561
05/25/14 03:18 PM
05/25/14 03:18 PM
East Texas
Mopar2DBone Offline
Mopar2DBone  Offline
East Texas
Looks good. What did you paint the steering gear with?
Re: Father/Son - BB D100 Project [Re: Mopar2DBone] #1624562
05/25/14 04:48 PM
05/25/14 04:48 PM
Grand Forks, ND
Hemi_Ram Offline
Hemi_Ram  Offline
Grand Forks, ND
Steering gearbox and frame I used rustoleum satin black. The gray parts you see are just a ceramic primer.
Re: Father/Son - BB D100 Project [Re: Hemi_Ram] #1624563
05/25/14 05:02 PM
05/25/14 05:02 PM
East Texas
Mopar2DBone Offline
Mopar2DBone  Offline
East Texas
Gotcha... Next question. Me and my son are fixing up a 81 Power Ram and have it down to the frame like yours. On the firewall, inner fenders, and core support what kind of prep work do you do before painting? We are not building a show truck but still want it to look nice.. Thanks..
Guess what I want to know is am I ok with just cleaning/degreasing everything really good and hitting it with a DA sander then shooting it with body color???
Re: Father/Son - BB D100 Project [Re: Mopar2DBone] #1624564
05/25/14 05:44 PM
05/25/14 05:44 PM
Washington State
Washington State
Is the steering box brace basically a backing plate and strut - factory piece?
We used Rustoleum on the frame too, Duplicolor on other components.
Degreased the firewall (and removed a ton black sealer/undercoat) before hitting it with a DA. Used Rustoleum inside the cowl. Going to prep the inner fenders and core support before spraying some primer on everthing. Going to give Summit Racing's repackaged "whatever" paint a shot on this one (after all my kid will be driving it).
Re: Father/Son - BB D100 Project [Re: 70Duster440] #1624565
05/25/14 07:12 PM
05/25/14 07:12 PM
Grand Forks, ND
Hemi_Ram Offline
Hemi_Ram  Offline
Grand Forks, ND
It is used to support the steering gearbox and I think you might find some on junkyard trucks. I got mine from the dodge connection but I don't see one on his website. Maybe scratch will chime in as he probably knows where you can find one.
Re: Father/Son - BB D100 Project [Re: Hemi_Ram] #1624566
05/26/14 12:09 AM
05/26/14 12:09 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
http://www.dodgeconnection.com/catalog/item/2901766/4541374.htm
Currently unavailable. Junkyard or make one
Re: Father/Son - BB D100 Project [Re: 76dodgeboy] #1624567
05/26/14 04:03 AM
05/26/14 04:03 AM
Washington State
Washington State
Thanks, guys.
Re: Father/Son - BB D100 Project [Re: 70Duster440] #1624568
05/26/14 04:22 AM
05/26/14 04:22 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I have a friend with a couple of those braces for sale if you want 1.
I am truckless..
Re: Father/Son - BB D100 Project [Re: 340SHORTY] #1624569
05/26/14 11:47 AM
05/26/14 11:47 AM
scratchnfotraction Offline
here is a stock plate for the outside of firewall MC area with a stock manual brake rod = rod 7" long.
you can get an adjustable rod from mancini. IIRC
I made an alum plate used larger bolts bolting it to firerwall and then 2 bolts thru firewall to a alum 2 bolt MC = stock mc from vac brake bosster.
IMHO I would use the alum 2 bolt MC over a cast iron MC.
I weighed all of my delete and add ons shaving a full 200lbs off the nose of my 88-440truck going manual steer/manual brake/alum intake/alum wp housing/ mimi starter/mini alt/ heater box delete/weld rims
weighs in under 3800lbs now with me in it.
Re: Father/Son - BB D100 Project [Re: scratchnfotraction] #1624570
05/26/14 11:47 AM
05/26/14 11:47 AM
Re: Father/Son - BB D100 Project [Re: scratchnfotraction] #1624571
05/26/14 11:48 AM
05/26/14 11:48 AM
Re: Father/Son - BB D100 Project [Re: 340SHORTY] #1624572
05/26/14 02:45 PM
05/26/14 02:45 PM
Washington State
Washington State
Thanks - how much?
Re: Father/Son - BB D100 Project [Re: scratchnfotraction] #1624573
05/26/14 02:53 PM
05/26/14 02:53 PM
Washington State
Washington State
Thanks for the reference, Scratchn' - appreciate it. The Mancini pushrods are apparently gold plated. But they do come with a retainer...
Re: Father/Son - BB D100 Project [Re: 70Duster440] #1624574
05/26/14 06:55 PM
05/26/14 06:55 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Thanks - how much?
Waiting to hear from him as to how much. The 2 he has left need some welding/repair where they bolt to the X member..
I am truckless..
