1st-time manual trans owner - 71 pistol grip Questions #1624264
05/23/14 11:44 PM
05/23/14 11:44 PM
Tennessee
WyleECoyote Offline OP
Tennessee
How do you know when / if you need a pressure plate; when is IT worn out?
This is my first manual trans car / experience so I'm on the learning curve!
Is there a "rule-of-thumb" for wear-and-tear of normal type driving, like two clutch discs to every one pressure plate? Is there anything you can tell by pedal feel or how it shifts or acts when engaged to know there is a pressure plate problem?
Also, how do you know when you just need to adjust the fork rod?
My car is a 71 Charger 500, 383 4-speed with 106,000 miles. I'm just now getting it running to where I'm going to take it for a drive and I don't know what to expect with the clutch and transmission.
I found this article and am reading it and trying to absorb what it says: http://www.procarcare.com/includes/content/resourcecenter/encyclopedia/ch20/20TSclutch.HTML
Any advice?
Re: 1st-time manual trans owner - 71 pistol grip Questions [Re: WyleECoyote] #1624265
05/23/14 11:53 PM
05/23/14 11:53 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Generally speaking which clutch component wears first isn't important, if I'm taking that much stuff apart I replace it all just to save tearing it all down again (likely) soon after to replace something else.
Re: 1st-time manual trans owner - 71 pistol grip Questions [Re: ScottSmith_Harms] #1624266
05/24/14 01:58 AM
05/24/14 01:58 AM
SHELBY TWP,,MICHIGAN
72N96RR Offline
I LOVE WEDGIES
72N96RR  Offline
I LOVE WEDGIES
Agreed..Replace everything everytime...Its not worth doing twice..
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free..
If they come back it means nobody else wanted them either..!!
Re: 1st-time manual trans owner - 71 pistol grip Questions [Re: WyleECoyote] #1624267
05/26/14 12:25 AM
05/26/14 12:25 AM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
couple tells I've come across when your clutch is fried
very bad smell comes through the floor like burning carpet
you can no longer shift out of the gear your in
you step on the gas and you can feel it "slip" (not engaging)
congrads on the new purchase
Re: 1st-time manual trans owner - 71 pistol grip Questions [Re: dangina] #1624268
05/26/14 01:56 AM
05/26/14 01:56 AM
Tennessee
Tennessee
Thanks Dangina! I'm just trying to learn; not that I disagree with replacing EVERYTHING while I'm in there - as a standard-shift car owner, I just want to learn!
Thank you Sir!
