Re: Old, old magazine article - 727 homemade shift kit
[Re: John_Kunkel]
#1623965
12/29/14 02:52 AM
12/29/14 02:52 AM
Posts: 1,377 Tennessee
WyleECoyote
Tennessee
I finally got up the ole attic and busted out the boxes of magazines and went through my Mopar Action mags and still can't find the mag with the awesome article on this shift kit. Anyone else come across it yet???
Wile E. Coyote Super Genius, Lover of FCA US LLC Products ************* 68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
[Re: gdonovan]
#1623971
12/30/14 08:50 AM
12/30/14 08:50 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
Page 4
Someone scanned in for me when I asked the question back in 2009, just passing the scans along.
"I think its got a hemi"
[Re: dvw]
#1623973
12/30/14 01:35 PM
12/30/14 01:35 PM
RapidRobert
To confirm, what dia drill bit in #9, is that 9/16"
[Re: 62maxwgn]
#1623975
12/30/14 03:09 PM
12/30/14 03:09 PM
RapidRobert
alright, 0.196" thank you. Agreed 9/16" it ain't likely you'd being going that big on a sep plate hole but it sorta looked like 9/16 in the pic so I wanted to clarify
[Re: RapidRobert]
#1623977
12/30/14 03:26 PM
12/30/14 03:26 PM
Posts: 74,942 U.S.S.A.
JohnRR
U.S.S.A.
What mag is that article in ? I have a ton of old mags getting ready to go to the recycle station , I'm tired of moving them...
after reading the first page I have to guess mopar action ??
[Re: goldmember]
#1623978
12/30/14 03:37 PM
12/30/14 03:37 PM
JohnRR
U.S.S.A.
Robert you confused the issue by putting in #9 instead of saying STEP 9 , as it says to use a
3/16" =.1875"
Not a #9 drill bit , which Bill correctly told you the size. I'm not sure how much a .009 bigger drill is going to affect the desired performance.
The article is confusing about removing a check ball in the upper half , but mentions a cup and spring or ball and spring but must remain ???
It's been a while since I've had a valvebody apart ...
[Re: RapidRobert]
#1623980
12/30/14 04:23 PM
12/30/14 04:23 PM
Posts: 25,726 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Enlarging the hole in step #9 only relates to '71 and later...that hole is already larger than 3/16" in the earlier VB's.
And, for the 4000th time, the advice in step #5 to toss the accumulator spring is based on the oldest myth in the Mopar world....DON'T DO IT
And, as I stated earlier in this thread, tossing the check ball in step #7 without rear servo mods is inviting severe overlap on manual 1-2 upshifts.
[Re: RapidRobert]
#1623982
12/30/14 07:46 PM
12/30/14 07:46 PM
John_Kunkel
Rio Linda, CA
I wouldn't eliminate any check balls in the lower VB (transfer plate). These check balls protect components by limiting fluid flow during application but drop away during release to speed the release.
One exception might be plow trucks in which the check balls delay rapid shifts between Drive and Reverse.
