Re: 1970 V-code Roadrunner
[Re: DPelletier]
#1623357
06/11/14 01:42 AM
06/11/14 01:42 AM
Posts: 3,106 Ridgeland Wi
mopars_1
Ridgeland Wi
pictures as promised. tubs are now all out and back to normal. just a little putty work and its golden.
1971 Plymouth Duster 340 auto 1937 Plymouth PT50 1969 Dodge Dart Swinger 340 4 speed 2013 Ram laramie 2500 hemi 2008 Harley FLSTSB springer
[Re: mopars_1]
#1623358
06/11/14 01:43 AM
06/11/14 01:43 AM
mopars_1
Ridgeland Wi
drivers floor tore out. little cleaning up to do. probably be mocking up floor pan tomorrow time permitting. more updates to come.
[Re: mopars_1]
#1623359
06/11/14 02:43 PM
06/11/14 02:43 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
[Re: mopars_1]
#1623361
06/11/14 05:46 PM
06/11/14 05:46 PM
mopars_1
Ridgeland Wi
some stuff painted up including the fenders. gaps were all checked before removal and paint.
[Re: mopars_1]
#1623363
06/11/14 05:47 PM
06/11/14 05:47 PM
mopars_1
Ridgeland Wi
and the rallys where blasted, primed and painted today. went with krylon dull aluminum.
[Re: mopars_1]
#1623364
06/24/14 12:57 AM
06/24/14 12:57 AM
mopars_1
Ridgeland Wi
little more work done. floor pan is welded in and cleaned up. also, been doing more putty work on the bottom side, but didn't get a picture of that. been busy doing field work when we can between rainy days..
[Re: DPelletier]
#1623365
08/23/14 07:28 AM
08/23/14 07:28 AM
mopars_1
Ridgeland Wi
Havnt been posting in a while but still been picking away at the car. Motor is almost done. Used a date coded block that came with the car. Nothing radical, but it has the stock rotating assembly, cant recall piston brand off hand but compression should be in the ball park of upper 9's. Cam is a mopar performance purple cam, and it going to run 452 heads with an original chrysler aluminum intake. Should be a tad better than stock anyway..
[Re: mopars_1]
#1623366
08/23/14 07:29 AM
08/23/14 07:29 AM
mopars_1
Ridgeland Wi
Some body work getting done
[Re: mopars_1]
#1623367
08/23/14 07:30 AM
08/23/14 07:30 AM
mopars_1
Ridgeland Wi
Filling holes in engine bay
[Re: mopars_1]
#1623369
08/23/14 07:32 AM
08/23/14 07:32 AM
mopars_1
Ridgeland Wi
All bolt on stuff is now painted.
[Re: mopars_1]
#1623370
08/23/14 07:33 AM
08/23/14 07:33 AM
mopars_1
Ridgeland Wi
Rest of body is now in primer. Some blocking to do obviously but a big step anyway. Should hopefully be in paint by the end of september.
[Re: mopars_1]
#1623371
08/23/14 07:36 AM
08/23/14 07:36 AM
mopars_1
Ridgeland Wi
Also aquired a low mile 4.10 dana out of an a12 car. The dana in there was out of a 67 and had been butchered a bit. Thats all for now
[Re: mopars_1]
#1623372
08/27/14 06:35 PM
08/27/14 06:35 PM
Posts: 8,827 Houston, Tx
hemi68charger
Houston, Tx
Very nice.....
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
