A big thanks to Todd Marsh @ Marsh Performance
#1622756
05/20/14 09:12 PM
05/20/14 09:12 PM
Posts: 2,915 A shed in England
Tig
A shed in England
Just got off the 'phone with Todd. He's just finished our 655 motor it made some great number on 93 octane and 11:1 compression. So much in fact, we now have the potential to run an 8 second pass at 3900lbs. The motor certainly has it, we just need to get the chassis working at this side of the pond. Thanks Todd
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
Re: A big thanks to Todd Marsh @ Marsh Performance
[Re: sasquatch]
#1622758
05/21/14 09:02 AM
05/21/14 09:02 AM
Posts: 3,210 robin hood country
deaks
robin hood country
Great stuff, cant wait to see it go down the track. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: Tig]
#1622759
05/21/14 10:19 AM
05/21/14 10:19 AM
Posts: 13,351 Marion, South Carolina [><]
an8sec70cuda
Very nice! Any details on the combo and what it made on the dyno?
[Re: an8sec70cuda]
#1622760
05/22/14 10:21 AM
05/22/14 10:21 AM
Tig
A shed in England
Hi Chip, Motor made 1042 hp @ 6400 and 950ft/lb @ 5300 on Todds dyno. 11:1 cr with 93 octane. Pump gas motor, racing fuel is so expensive over here. It's a 655ci Indy block with 600-13 heads, raised cam, 4.840 bore centre line. Cast intake 2x4. Wet sump. Should be very streetable
[Re: Tig]
#1622762
05/22/14 10:48 AM
05/22/14 10:48 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Very nice... cudos to Todd
[Re: roadhazard]
#1622763
05/22/14 12:17 PM
05/22/14 12:17 PM
Tig
A shed in England
We need some pictures
So do I
[Re: Tig]
#1622764
05/22/14 01:20 PM
05/22/14 01:20 PM
an8sec70cuda
Simply bada$$. Can't wait to see pics and hear how it runs. I'm gonna need some video...stat. Thanks.
[Re: Bigcube]
#1622766
05/23/14 02:01 AM
05/23/14 02:01 AM
Posts: 2,644 North Carolina
sasquatch
North Carolina
Recipe for engine. Carbs Massive. Intake Cavernous. Heads Gigantic. Valves Platter like. Pistons You could bathe babies in the dish. Cam Not as big as you think. Crank and rods Big. Rockers Expensive. Cost Really Expensive. Seriously if Tig oks it I will share some more info but only with his blessing. It is his now.....And yes I will take some pictures of it. Honestly other than the gen 3 dominators it looks like a big INdy wedge with a Milodon pan and belt drive. Oh and the requested purple wires...... Todd
[Re: sasquatch]
#1622767
05/23/14 02:09 PM
05/23/14 02:09 PM
Tig
A shed in England
Hi Todd. I don't have a problem with you giving out the details,
[Re: Tig]
#1622768
05/24/14 12:43 AM
05/24/14 12:43 AM
sasquatch
North Carolina
ok here ya go. Indy max block with raised cam and 4.84 bore space. Clearanced for a 5 inch Callies crank and 6.95 GRP rods. Lots of clearance grinding. Standard Milodon dual line with Swinging PU. Pistons are custom Diamonds with a 33 cc dish. They look like diesel pistons. 043 ring low Tension oil ring. Jesel belt drive up front. A few custom touches to the block to aid in drain back. 55 mm flat bearing cam with a 4/7 swap. 7/16 Manley pushrods, COmp ultra pro lifters. 1.8 Jesel rockers slamming 2.450 1.81 Titanium valves in 600-13X heads with our full port treatment. Copper head gskt and ARP hardware. INdy tunnel ram with the full treatment and two 1150s GEN 3 dominators. Msd Probillet and Taylor PURPLE wires. ATI dampner and Tig has a crank trigger for it. I ran it with a Star Machine Vaccuum pump. It pulls over 800 ft/lbs from 4000 to 7000 with peak at 5400 of 950. I layed this motor out with the help of Mike Barrett and head and manifold guru Larry Smith. We had to be really careful with this one due to the low compression. We had previously only done these with Big compression and cams. Cams ah yes. All I will say about that is it has .485 lobe lift. I will post some pics tommorrow. Good night all. Todd
[Re: sasquatch]
#1622769
05/24/14 01:06 AM
05/24/14 01:06 AM
I would add That is one of the truest dynos in the land--those numbers are REAL Congrats on a Wicked Mopar build!!!!!!!
[Re: camastomcat]
#1622771
05/24/14 01:28 PM
05/24/14 01:28 PM
Tig
A shed in England
Awesome....Really pleased Looks like we're getting a handle on the chassis tune. We've just smashed the crown wheel and pinion in the Dana
[Re: Thumperdart]
#1622775
12/04/14 04:10 PM
12/04/14 04:10 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
WOW is all I can say............
I will second that!
Mark
[Re: camastomcat]
#1622776
12/04/14 06:28 PM
12/04/14 06:28 PM
Posts: 1,823 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
Really impressive Todd. All of your effort paid off. IMO, Todd is the best Indy dealer to work with, or any parts for that matter. Not dissing any of the other guys, he's just very savvy and honest. Steve gill does well too.
Thee best ever Sasquatch. Todd goes over everything & is a straight shooter. Buy all your Indy parts from Todd Marsch.
[Re: Hemi Allstate]
#1622777
12/06/14 02:53 PM
12/06/14 02:53 PM
Tig
A shed in England
[Re: roadhazard]
#1622783
12/07/14 03:01 PM
12/07/14 03:01 PM
Tig
A shed in England
What are those blue things by the water pump holes
That's how it come but I'm not going to tell on Todd
[Re: Tig]
#1622784
12/07/14 03:32 PM
12/07/14 03:32 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
I will
Other than that it looks great Tig
[Re: Thumperdart]
#1622786
12/07/14 09:38 PM
12/07/14 09:38 PM
roadhazard
Akron, Ohio U.S.A.
Greg..............ur box is full. Did you ever send me those pics of your carb? Sorry 2 hijack..........
Sorry I'll get it cleaned out
I have them pics for ya
[Re: Tig]
#1622790
12/09/14 10:59 AM
12/09/14 10:59 AM
an8sec70cuda
Looks awesome!!!
[Re: ultimatelenny]
#1622792
12/09/14 06:17 PM
12/09/14 06:17 PM
Tig
A shed in England
Hi Lenny. Thanks again for the excellent deal on the converter Appreciate it
[Re: Tig]
#1622793
01/17/15 03:53 PM
01/17/15 03:53 PM
Tig
A shed in England
Well.. out with the old
