68 B-body floor pan thickness? #1621397
05/17/14 10:40 PM
05/17/14 10:40 PM
Tennessee
WyleECoyote Offline OP
Tennessee
I am making some mods to my floor pans and need to rebuild some portions; what gauge or thickness sheet metal do I need to order / use to be consistent with original metal? Easier for welding right?
Thanks!
Re: 68 B-body floor pan thickness? [Re: WyleECoyote] #1621398
05/18/14 01:30 PM
05/18/14 01:30 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I can't speak for that timeframe but in this day and age all the sheetmetal is spec'd by the auto manufacturer to provide the necessary strength at the minimum weight (read cost !!). This means that standard gauge thicknesses are thrown out the window. All steel is rolled to those specs. So if that's how they did it then then you're going to have a problem matching it exactly.
This is also why much of the replacement sheet metal is not the same gauge as original. The reproduction companies can't afford to buy in the quantity required by the steel mills to run a custom gauge. Also to keep costs down they could be buying overruns of a "close" gauge.
Re: 68 B-body floor pan thickness? [Re: Stanton] #1621399
05/19/14 02:38 PM
05/19/14 02:38 PM
dogdays Offline
dogdays  Offline
I doubt you're going to run into that. 1966 was in a different millenium. CAFE meant a place to get coffee and a piece of pie.
I'd go with 18 gauge.
R.
Re: 68 B-body floor pan thickness? [Re: dogdays] #1621400
05/19/14 03:09 PM
05/19/14 03:09 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Re: 68 B-body floor pan thickness? [Re: dogdays] #1621401
05/19/14 03:33 PM
05/19/14 03:33 PM
Tennessee
Tennessee
R.
Thanks Dog (R.)!
Wile E. Coyote
Super Genius, Lover of FCA US LLC Products
68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
