Re: 5/16 pushrods with solid roller
[Re: skrews]
#1616146
05/05/14 01:26 AM
05/05/14 01:26 AM
Posts: 3,414 Toronto
mshred
Toronto
I had Smith Brothers make a set of 5/16 intake and 3/8 exhaust pushrods for my solid roller Indybrock headed motor. Had .712 lift with 245# seat 650# open. Would turn that motor 7300. No issues. Told them to give me the best they could on the intakes.
Any idea on the wall thickness of the 5/16 ones?
[Re: skrews]
#1616148
05/05/14 09:30 AM
05/05/14 09:30 AM
Posts: 20,622 in a cattle trailer down by th...
Guitar Jones
I'm using Trend 5/16 pushrods in my engine .118 wall thickness IIRC.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Guitar Jones]
#1616149
05/05/14 01:18 PM
05/05/14 01:18 PM
Triple Threat
Renton Washington
Smith Brothers 5/16 .120 wall here. 275 on the seat, 600 open. Still going after 225 runs.
[Re: Streetwize]
#1616152
05/05/14 03:05 PM
05/05/14 03:05 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Was just told about these thicker 5/16 push rods. You can buy a variety of stepped and tappered pushrods. If you know you lengths enter that number on eBay and you would be surprised what's out there cheap. I just got some 9/16 8.300 pushrods with long tapper and short tapper for about what you would pay for lash caps lol.
[Re: Streetwize]
#1616153
05/05/14 03:13 PM
05/05/14 03:13 PM
mshred
Toronto
Manton makes a nice 11/32" pushrod.
I am not sure even the 11/32 stuff would fit. The 5/16 is already very close to touching the lifter bore
I have heard that too thick of a wall thickness on a small diameter pushrod can actually weaken the design...any truth to this?
[Re: Leon441]
#1616154
05/05/14 05:39 PM
05/05/14 05:39 PM
mshred
Toronto
I will check that out!
Wondering if anyone runs less then .120" wall 5/16 stuff and if it works ok
[Re: Triple Threat]
#1616155
05/05/14 08:03 PM
05/05/14 08:03 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Same set up here on my Rampage
[Re: mshred]
#1616157
05/05/14 08:43 PM
05/05/14 08:43 PM
MR_P_BODY
The nitrous is what slightly worries me about using such a small pushrod...for some reason I am having serious issues pulling the trigger on this- the 5/16 just makes me feel uncomfortable for some reason, but I have no choice at this point
Spring pressure is spring pressure.. if its strong enough to hold the rev then the PR will
[Re: MR_P_BODY]
#1616158
05/05/14 08:53 PM
05/05/14 08:53 PM
mshred
Toronto
True
I also wonder if my pushrod issue is because I have a factory roller block with a slightly larger lifter boss, or if everyone has the same issue with the Indy stuff?
[Re: mshred]
#1616159
05/05/14 09:12 PM
05/05/14 09:12 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I am using 11/32 x .120 wall and I am running the 360-2 Indy heads. Mine are 7.605 and 7.640 length Manton pushrods.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: D-50]
#1616160
05/05/14 09:20 PM
05/05/14 09:20 PM
mshred
Toronto
How close are the intake pushrods to the lifter bosses on your setup? Did you open up the pushrod holes in the heads at all to get that size to fit?
[Re: mshred]
#1616161
05/05/14 09:27 PM
05/05/14 09:27 PM
D-50
North, Alabama
I bought the heads used and ported by Brett Miller they were probably clearenced already. I do not remember how close they are to the lifter bosses. I am running a 1973 340 block.
[Re: D-50]
#1616162
05/05/14 09:28 PM
05/05/14 09:28 PM
mshred
Toronto
Cool. Are you also running different length intake and exhaust pushrods? or did you get the same length for each?
I hope that 5/16 will be sufficient...I just feel really uneasy about this lol
[Re: mshred]
#1616163
05/05/14 09:39 PM
05/05/14 09:39 PM
D-50
North, Alabama
My intake and exhaust push rods are different lengths.
