window crank removal on 42 truck #1615776
05/04/14 02:17 AM
05/04/14 02:17 AM
Shelby, Ohio
2
2abodymcodes Offline OP
Shelby, Ohio
what holds the window crank and inside door handles on a 1942 dodge truck ? i don't see any clips around the shaft.
Re: window crank removal on 42 truck [Re: 2abodymcodes] #1615777
05/04/14 12:19 PM
05/04/14 12:19 PM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
i cant say with 100% certainty but in my 47 Desoto I had to push in on the door panel(there is a spring behind it on the window crank) there is a small pin that goes through the post and crank that can be removed with a punch. not the easiest thing to remove.
Re: window crank removal on 42 truck [Re: 65rbdodge] #1615778
05/04/14 01:34 PM
05/04/14 01:34 PM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline
Mopar Ron  Offline
what he said
you need to push in on the excussion(SP) plate and use a small punch or ice pick and push the little pin out and remove the handles.
see the pics below to see where the pin goes through the handle...
Re: window crank removal on 42 truck [Re: Mopar Ron] #1615779
05/04/14 02:29 PM
05/04/14 02:29 PM
Shelby, Ohio
2
Shelby, Ohio
thank you.
